Home > Technical (L322) > Headlights
Page 1 of 5 12345>
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Headlights
My headlights don't seem bright enough in the dark (dipped beam). I'm comparing these to my D3 which were pretty good, original lighting not messed with. Would changing the xenon bulbs make a difference? Do they get dimmer over time? High beam seems fine, although I'm sure it's still not as bright as the D3.
Post #293000 14th Nov 2014 6:45pm
given the age of your FF the xenon bulbs should be fine ..are the headlights adjusted correctly? ... - .- -.
Post #293002 14th Nov 2014 6:49pm
Lad
Cheers Stan, I've done a search regarding the lights and found the adjusting hex heads. They do seem low down on the road, especially the drivers side one. They really seem dim though. I did change the xenon bulbs in the D3.
Post #293005 14th Nov 2014 6:55pm
you could change to 6000k bulbs which technically are not as powerful as the standard 4300k ones but they do give a clearer whiter light..
i think once you have adjusted yours they should light up the road batter.... ... - .- -.
Post #293007 14th Nov 2014 6:59pm
Lad
Ta, I'll see if I can adjust them, don't want to dazzle other road users. Maybe I could also change the bulbs too. I think I got the last ones from hid sponsor on the D3 site. Can you buy them anywhere? What's the official name and part number of these bulbs? Thumbs Up
Post #293010 14th Nov 2014 7:04pm
i think they are D3S bulbs... ... - .- -.
Post #293013 14th Nov 2014 7:12pm
Lad
Ta. Thumbs Up
Post #293015 14th Nov 2014 7:13pm
Lad
Been out tonight and the lights look like they need adjusting. Seem to throw the beam of light right in front of the car and then when I put main beam on it throws the light not much further than dipped beam. Although it blinking blinds me with the reflection on the white road signs. Decided I'm going to buy some Philips X-treme d3s bulbs that they RECKON they are 50% brighter. As anyone bought some of these and if so are they better than the normal ones?
Post #293236 15th Nov 2014 7:34pm
Shocked those are expensive....... ... - .- -.
Post #293240 15th Nov 2014 7:39pm
Lad
£40 more each bulb but if they ARE brighter as they say they are I'm sure it's money spent well. I like to see where I'm going at night Very Happy
Stan, the other lights that are in the centre bit next to the grill, are these normal H7 bulbs? Might change those too. I did on the D3 and it did make a difference.
Post #293242 15th Nov 2014 7:53pm
yep they are h7..not that they are much use as road lights but i changed mine to whiter ones .. ... - .- -.
Post #293247 15th Nov 2014 8:15pm
Lad
Thanks Stan Thumbs Up aye just to compliment the xenons when on high beam. Can't remember which philips h7 I bought last time but they were whiter than the standard bulbs.
Post #293252 15th Nov 2014 8:21pm
Lad
Are these easy to replace? The Philips bulb looks like its got the 3 pin plug on the end is that correct? Can't remember what was on the end of the D3 bulbs as Pete Bell changed em. TA
Post #293255 15th Nov 2014 8:27pm
headlights out, put a cloth or some protection on the bumper cos its easy to scratch when removing the headlight units...
the d3s bulbs have a square base with a plug thingy on one side. ... - .- -.
Post #293279 15th Nov 2014 9:39pm
Id be very interested to see how you get on with the Phillips bulbs sir Bow down
I have changed the H7 full beam bulb for a Xenon kit which is FANTASTIC Thumbs Up Makes a HUGE difference to the full beam light Thumbs Up
Post #293289 15th Nov 2014 9:56pm
Page 1 of 5 12345>
