Home > Maintenance & Mods (L322) > Battery Fitment
keefy1959
United Kingdom 2006 Range Rover Vogue SE Supercharged Buckingham Blue
Battery Fitment
Hi all,
i will have to fit a new battery to my car this week and it looks a real pain to get out due to the limited space and i was wondering if i disconnected the gas springs[bonnet stays] would the bonnet lift back far enough to get a straight lift on the battery? also are there any other things i should be aware of as i have heard a few horror stories of keys getting locked in cars, mileage counters reading all the nines and media centers refusing to work etc, i intend fitting a FIVE STAR 019 battery as this is the one recommended unless you guys can come up with a better solution!!
thanks in advance for your help!! Cool Supercharged 4.2 FFRR in Buckingham Blue,
Gone, Ford Explorer 4.0 V6 petrol,
Gone, Ford Granada Estate Ghia,
Gone, Daimler sovereign 4.0,
Raced, more mk1 & 2 granada's, A60's mk1 cortina's and mk 3 zodiacs than i can remember!
If its too loud then you are too old!!!
Post #293412 16th Nov 2014 10:54am
putting the bonnet in service mode will make fitting the battery much easier, still a fiddly job and maybe a stool/platform to stand on will help....dont do it on a very windy day though... ... - .- -.
Post #293416 16th Nov 2014 11:02am
Weegie
A How to
 John
GAP iiD BT-Sold
Post #293419 16th Nov 2014 11:04am
keefy1959
Cheers guys!! i'll give it a go!! Mr. Green Supercharged 4.2 FFRR in Buckingham Blue,
Post #293438 16th Nov 2014 12:04pm
Sandyt
Did mine following the WIKI on here in next to no time Thumbs Up Thumbs Up
Post #293441 16th Nov 2014 12:12pm
keefy1959
Thats very helpful!!! although i was always taught to remove the earth lead first and put it back last, does this not apply to our rangies!! Confused Confused Supercharged 4.2 FFRR in Buckingham Blue,
Post #293449 16th Nov 2014 12:33pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Yes, negative terminal first and last, don't trust anything you see on the net.
In that video, with the negative terminal still connected, if his spanner touched the bodywork metal anywhere (easily done in that confined space) then it would be a direct short. With the negative disconnected no such issue.
Post #293454 16th Nov 2014 12:57pm
Sandyt
If you follow the WIKI on here first do the battery disconnect then the removal one and you will have no issues Thumbs Up
Post #293455 16th Nov 2014 1:01pm
keefy1959
Cheers fellahs!! Supercharged 4.2 FFRR in Buckingham Blue,
Post #293467 16th Nov 2014 2:29pm
Landphil
My battery is OK at present but at 4 years old and no sign of much preventative maintenance, just servicing, I am getting ready for potential battery issues this winter. The battery is charging on my CTEK but takes a long time to charge, much longer than on my D4 and it's the same battery.
My question is about removal and replacement. I have studied the Wiki and that was a great help. However, on my car there is a piece of kit (looks like some sort of cooling radiator) bolted onto the back of the plastic bulkhead in front of the battery and this would, I think, stop the battery being lifted out.
So question is, what is it and does it have to come out to replace the battery.
It's dark now so if required a picture will appear tommorow.
Thanks
Phil
Post #409182 13th Oct 2016 7:07pm
Landphil
I have partly answered my own question. To remove the baterry in this car you have to remove the wiper arms and the windscreen valance to create enough space to lift the battery out and lift the new one in.
As for indenifing the part in front of the battery no luck yet.
Post #409277 14th Oct 2016 11:33am
rar110
I replaced my battery sort of unexpectedly. I went to my battery supplier expecting to buy a battery and take it away to fit at my convenience. It turned out to be a warranty replacement on condition I handed over the old battery, without assistance. So I bit the bullet and did it based on memory of what I've read here and elsewhere.
The bonnet up system is a great design. Quite straightforward. I also disconnected the negative terminal first.
I didn't have to remove anything like the wipers to replace the battery. ______________________________
Post #409279 14th Oct 2016 12:06pm
Landphil
I too thought it would be very straight forward after studying the procedure in the Wiki, but on examining my car it is not simple. As you say the bonnet design is great and I can do that easily, but the hole, through which the battery has to pass is much smaller than the battery unless something is taken out. From what I can see removing the wipers and valance is the soft option, but interested to hear from the more experienced if this is the case. I don't know what changed from the car in the Wiki to the MY12 that I have but there is more kit in that area than shown on the demo.
Phil
Post #409281 14th Oct 2016 12:28pm
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
changed my battery today as wiki no need to remove anything else took all of an hour with a coffee and waiting to shut down
Post #409327 14th Oct 2016 7:52pm
Landphil
Not with this lot in the way. What model is yours?
Post #409350 14th Oct 2016 11:08pm
