Home > Technical (L322) > Which remote do I need for FBH on a 55 plate car..
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
I'm missing the remote for the FBH on my Range Rover, the car is a 55 plate td6 does anyone Know which remote will work as I see there is a T90 or T91 types. Thanks
Post #293299 15th Nov 2014 10:27pm
Afaik, the t91 is the later remote, and is the one I have on the disco4, my ffrr is earlier and has a t90. It's the larger one more triangular in shape than the 91, which is small and oval. There is nothing that can't be fixed with a hammer😜😜
Post #293379 16th Nov 2014 9:07am
JPS
Thanks for clearing that up mate, so a later t91 remote wouldn't work on my car?
Post #293425 16th Nov 2014 11:23am
Not sure, to be honest. I didn't try syncing the t91 with the Ffrr. The reciever for the disco is labeled t91r though so maybe they are matched.
eBay Item No. 390362071723
This one should work though seems a bit pricey. Open to offers though. Wortg asking dan how much for a new one, think the t91 was about £80 so probably in that ballpark. There is nothing that can't be fixed with a hammer😜😜
Post #293429 16th Nov 2014 11:40am
Discotigger
The T91 oval remote should work on your FF, being a 55plate model (with the touchscreen satnav system, I presume).
I have an 05 model TD6 and I've got the T91 remote, which works fine on my vehicle. Thumbs Up
Pairing the new remote to the FBH receiver can be a bit of a pain though, check the wiki how to on this site for details.
Post #293461 16th Nov 2014 1:36pm
http://www.webasto.com/fileadmin/webasto_f...rt-t91.pdf
If the t91 works which it seems it does, these are the instructions including how to pair it. There is nothing that can't be fixed with a hammer😜😜
Post #293463 16th Nov 2014 1:50pm
JPS
Thanks guys, I think I will take a punt for the T91 remote as there only £30 brand new on eBay, yes my car has the touchscreen nav and is a facelift model. Will let you know the outcome and thanks for the instructions these will come in handy Thumbs Up
Post #293487 16th Nov 2014 3:38pm
stcstc31
Ireland 2005 Range Rover SE Td6 Atacama Sand
the the remote an option or should they work with all cars?
Post #293489 16th Nov 2014 3:42pm
As above, the T91 like i sell should be perfectly fine Smile
Only downside compared to the T90 is a much smaller range but still pretty decent Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #293501 16th Nov 2014 5:04pm
stcstc31
u still got some left, and does ever car come as standard with remote?
Post #293508 16th Nov 2014 5:33pm
JPS
Thanks mate, do you sell them on ebay? Thumbs Up
Post #293517 16th Nov 2014 6:05pm
Discotigger
All doozel FFs (TD6, TDV8, etc.) have the FBH fitted as standard and could be fitted to the petrol models as an option, but I'm not sure if all doozel model variants have the remote receiver fitted as standard. Easy way to check is to look in the right rear loadspace bay, if there's a receiver fitted behind the fuse panel then you should be able to get a remote to operate it.
Post #293538 16th Nov 2014 7:14pm
stcstc31
ah ok cool. thanks
Post #293544 16th Nov 2014 7:26pm
Not all variants have the remote reciever, so double check. Just seen another post by noddy, which says the t60 reciever will not pair with the t91 so check which version you have. There is nothing that can't be fixed with a hammer😜😜
Post #293552 16th Nov 2014 7:36pm
JPS
Received the T91 remote today and programmed it very easily and now works a treat. Just need the temp to drop below 5 degrees now Thumbs Up
Post #294024 18th Nov 2014 9:14pm
