![]() | Home > General > Jump Battery points |
Having to jump start the small Fiat that i tow behind the Motorhome from the FFRR, what are the best jumping points on it i know where the positive connection on the FFRR body is , but is there one like it for the earth instead of going direct to the battery as it can be a bit of a tight squeeze attaching a jump lead to it ...... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
the negative is a nut on the top of the strut and the positive is en-cased in a plastic box right by the strut/bulkhead...i know the FFRR has a hefty battery but its always better to have the doner cars engine running.. ... - .- -.
RTFM? |
ROFL. Oh, and thanks for changing your avatar, Mick. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Would if i could find the F ![]() @SteveMFr ........ so what was wrong with the avatar !!!!!!!!!!!!! |
taken from the AA site.
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 ![]() ![]() |
If I recall the manual cautions about jump-starting directly from the battery due the pyrotechnic cutoffs on earlier models - post 07(ish) the pyros were changed to a cleverer system that allows some systems to work in a crash.
Hmmm, I dunno, maybe I enjoy looking at RR fronts more than ZOMBIES? ![]() ![]() ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Fix it again, Tony? |
Just for fun, try getting the leads mixed up! Lovely smell of melting plastic and red hot glowing metal. The FFRR survived, as did the MX5 |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Why not use the engine battery from the motorhome rather than risking expensive damage to the RR's electronics - unless the caravan's battery is also iffy.................... 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Motorhome too far from the wee fiat , plus too much hassle to get them in position ....... |
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
If you are worried about the RR electronics why not invest in a power pack. About £100 will get you a decent one and for that price you will be able to charge it off of 12V in the motorhome... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior |
