![]() | Home > Wheels & Tyres > Largest tyre size to put on 20" rims? |
I agree mate, either stick to the factory size or more sidewall |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I think this has been asked many times but I think it's 275 45 20 which are often on merc ML's but don't quote me. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818 ![]() ![]() |
it is 275 45 20 - these are the closest to std OEM. Most 275/45 are slightly less in diameter by a few mm.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Can you use 55 instead of 45 as i prefer more rubber _____________________________________________________
not sure re 275/55 - as it is wider and taller - there may be a clearance issue on the struts. 255/55 are OK AFAIK as many have fitted the 255/55/20 off the L405 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874 ![]() ![]() |
note that FF rims are 8.5j and RRS rims [which fit the FF] are 9.5j ....i had 295 45 20 tyres on RRS rims fitted to my td6 for quite a while... ... - .- -.
Fit 19's or 18's. They're fab.
BlackPerth Member Since: 13 May 2008 Location: Brisbane Posts: 114 ![]() ![]() ![]() |
I have Cooper Zeon LTZ on 285/50/20 and they JUST fit. Have been very good on and offroad (quiet too).
Not all FFs can go smaller than 20 inch wheels, like my 5.0 for example.
devonchilliman Member Since: 06 Jan 2015 Location: Devon Posts: 348 ![]() ![]() ![]() |
Blackperth...
Nope, none! |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
285/50R20 gives an outer tyre diameter (according to good old fashioned maths) of 650.8mm
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 ![]() ![]() ![]() |
What about the speedo readings going bigger? 2004 RR 4.4 V8 Autobiography |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2721 ![]() ![]() ![]() |
275/55/20 on mine, speedo being out is really a myth, maybe by a midge's ball hair but that's it!might be tempted to part with them too, not had a bad winter for a while so they're sat in the garage..... |
