Home > Maintenance & Mods (L322) > Transponder chip
Transponder chip
Anyone know if these actually work and who can program them??
He's sold loads!!!
http://www.ebay.co.uk/itm/KEY-CHIP-LAND-RO...20d9c0d68e Pete
-Click here for Thread-
Post #293991 18th Nov 2014 7:17pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
The shop in the town where I live can program blank transponder chips, but he needs an original key and the vehicle. He also cuts the key, that's where I am going when I get 2 keys from Daveo.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #294016 18th Nov 2014 8:46pm
daveo
quite easy...will not work.. you need to read the ews in the car to get the key data. ebay man is talking bull as they can not be pre programmed to land rover as its a BMW security system, the chips can only be written to once
he is just selling the chips
he all so goes on to say he does not know about chips and programming
later range rovers 06 and on, when you buy the key from land rover are pre coded but still need to be activated V8 facelift Range Rover Autobiography 22" wheels.
Post #294018 18th Nov 2014 9:00pm
Thumbs Up Pete
Post #294023 18th Nov 2014 9:11pm
Discotigger
Seems like a bit of a con to me, only £5 and no returns accepted.
I would steer well clear...if not sure.
This ebay seller at least gives the proper description
http://www.ebay.co.uk/itm/New-ID46-Transpo...493wt_1207
Says has to be programmed by MD or locksmith
Post #294025 18th Nov 2014 9:14pm
daveo
to be honest, i can do the chips but i have to remove the ews to read the key data as its a rolling code, there may be newer software around now as it changes so fast that can do it through the obd port, but when i was looking all the good stuff can be very expensive. V8 facelift Range Rover Autobiography 22" wheels.
Post #294035 18th Nov 2014 9:47pm
Discotigger
Just out of curiosity, does the transponder chip just 'unlock' the ignition, or does it have any other function-i.e.for memory settings, etc., or is that done by the circuit board in the key fob?
Post #294044 18th Nov 2014 10:17pm
