Home > Technical (L322) > Headlights
Page 3 of 5 <12345>
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
cheers stand, all have a mother look tomorrow morning.....so we mean take the unit off the car so to speak to change the bulbs rather than access from the back? that would make sense as it looks a little snug Wink
Post #293955 18th Nov 2014 5:29pm
the headlight has to be taken off the FF to change any bulbs in the unit, very easy to do but make sure you have a cloth or something on the bumper as it can get scratched... ... - .- -.
Post #293957 18th Nov 2014 5:33pm
Lad
England 2010 Range Rover Vogue SE TDV8 Santorini Black
New bulbs IN. Didn't take out the headlight to fit the xenon and the full beam light. Much brighter, more coverage on the road too. We checked the alignment of the light before changing bulbs and it was spot on. We looked at the throw of the light and it started off initially bright and went slightly dim after 5-10 secs. Replaced the xenon and checked again, the light started of quite bright and then got brighter over 5-10 secs and again it was spot on on the alignment. The new H7's made a great difference over the bulbs that were in.
So I'm really happy now.
Thanks for all your inputs (especially Stan) Thumbs Up
Post #293998 18th Nov 2014 7:35pm
nice one Lad Thumbs Up
so you recommend these 50% brighter jobbys then.. ... - .- -.
Post #294027 18th Nov 2014 9:17pm
Lad
Hard to say Stan, in my case there was a big improvement but my original bulbs weren't that good. They are a lot brighter. The ones I put in the D3 weren't these bulbs and I think these are brighter than the ones in the D3. Full beam is A LOT better.
I think if you are happy with what you have at mo leave them, until you need to change them.
Hope that's a little help. Wink
Post #294060 18th Nov 2014 11:49pm
mine are fine but xmas is coming and i need to ask santa for something Mr. Green ... - .- -.
Post #294093 19th Nov 2014 7:34am
andyleeds
Lad
have you got the links to the two types of bulbs that you bought?
also did you say that you changed them without taking the headlamp off?
andy
Post #294124 19th Nov 2014 10:45am
Seabass
Sweden
I've been wanting better lights since I got my FF, after reading this I've ordered these and I hope they will improve the output on mine aswell Thumbs Up 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Swedish LR club member #5333
Post #294148 19th Nov 2014 2:03pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Off on a slight tangent, the standard dip beam headlights on the MGTF were Censored .
I have just fitted some H7 Nightbreakers and found a massive improvement although some reviews say they might not last as long. They are standard spec so no risk to wiring by fitting more powerful lamps. I am going to get some to upgrade the Mainbeam and foglights on the RR Mine was a blue one! Smile
Post #294152 19th Nov 2014 2:48pm
andyleeds
one further question men, which is the bulb that is used when normal night driving i.e. NOT on main beam as i find that the normal lights are the ones that are a bit poor....
Post #294372 20th Nov 2014 2:12pm
you have a xenon bulb which is active on dipped beam , when you flick the high beam on there's a little flap that 'opens' up that same bulb to high beam, also the h7 halogens come into play ... ... - .- -.
Post #294386 20th Nov 2014 4:38pm
andyleeds
ah so its the same bulb for main beam and high beam and those bulbs are the ones at £90 a pop.... gotcha
cheers stan
Post #294391 20th Nov 2014 5:13pm
only the philips extremes are around that price , you can get decent 6000k ones for about £30 a pair on ebay..
and before anyone says that these are rubbish then thats not true, ihad some on my td6 and they were fine... ... - .- -.
Post #294401 20th Nov 2014 5:52pm
andyleeds
We're they significantly better than the original ones? As I don't rate mine at all.... I almost want to drive all the time on high beam
Post #294478 20th Nov 2014 11:13pm
technically the 4300k temperature is brighter than the 6000k but these were whiter light so it gave the impression of being brighter...
i also cranked up the height of both headlights to make them 'beam out' further.. ... - .- -.
Post #294479 20th Nov 2014 11:18pm
Page 3 of 5 <12345>
