![]() | Home > Technical (L322) > locking diff / axle fluid. |
| woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259
Good morning Gents,
| paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422
Woodchopper
Thanks for the information Paul. I assume if I have adaptive terrain control , that I have the electronic differential that you are referring to ?
Not sure WC...
I'm waiting to go back to the dealers for the upper tailgate replaced. I'll find our then if terrain response equals electronic diff. I think it must as how else would terrain response work? MY2010 TDV8 Vogue Ipanema Sand
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
If you go to the 4X4 screen and dial in rock crawl on the terrain response do you get two open padlock symbols ? one over the centre diff and one over the rear diff . this will tell you if the diff is open or closed and for the rear one if it the e-diff is fitted. 2008 MY Supercharged
| IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502
If you look at the rear diff you will see some wires going to it if it is a locking diff. |
WC...TR also adjusts the suspension height and throttle response for a given dialled in surface / terrain...
| Mark L Member Since: 29 Oct 2014 Location: Tamworth Posts: 121
Given the reoccurring problems FFRRs seem to be facing with heavily contaminated rear diff oil, I'd personally be looking to change it every 12 months with a rear locker... |
| All times are GMT |
