Home > General > Air con.. Do you leave yours on all year round?
Page 1 of 4 1234>
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
I just had my air conditioning regassed as it wasn't working, was certain I would need a new condenser but they said there were no leaks and it just needed regassing so is now icy cold. The guy said its best to leave it on all the time and just adjust the temp as required, do you guys leave yours on constantly? Was wondering if so does it affect your fuel economy much?
Post #294151 19th Nov 2014 2:46pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
i leave mine on all year round
keeps all the windows clear of condensation
De-mists the windows in no time
also air-con needs to be run regularly to lubricate the pump and stop the seals drying out
supposed to be more economical than driving with the window open over a set speed
last note
if its economy you want you have the wrong vehicle
Post #294155 19th Nov 2014 3:05pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
I leave mine set on 18 degrees everything on auto and let it sort its self out. Not using on a regular basis causes more problems and you can end up with damp musty smell coming from the vents.
If you are worried about economy and the small difference aircon or or off would make I think you have the wrong vehicle. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #294156 19th Nov 2014 3:05pm
RiccartonRR
As above - I leave it one, set the temperature and let the system work it out.
Loads of benefits having it on all the time - one tiny benefit turning it off when not needed. However, any slight saving you may make in economy will be wiped out many times by the cost of maintenance to a dried out pump etc.
Post #294168 19th Nov 2014 5:10pm
nobbyclark
If it's like mine, it comes on by default when you switch on. I always switch it off unless I need to cool down (which hasn't been the case in the 6 weeks since I've owned it) or else to demist the car when we all get in soaking wet (which has been the case for most of the 6 weeks since I've owned it).
Post #294179 19th Nov 2014 5:34pm
Sandyt
I also leave mine all year for all the good reasons the others have mentioned. Thumbs Up
Post #294184 19th Nov 2014 5:51pm
JPS
Thanks people, I will leave it on all the time then, can't believe how cold this system gets, is better then any other car I've had previously
Post #294185 19th Nov 2014 5:52pm
markyp
England 2004 Range Rover Vogue Td6 Zambezi Silver
Leave mine on, Fuel Economy Laughing 2004 vogue
1978 Pontiac Firebird
2010 Fiesta
Post #294229 19th Nov 2014 9:25pm
mjdronfield
There are 2 types of people that don't run it all the time. Those that are going to get a big air con bill and be skint, and those that are going to get a big air con bill and not be skint.....
Seriously though, the system needs to be run to move the refrigerant round and keep the rubber seals lubricated. Otherwise they go dry, crack and the gas leaks out........
Plus as posted already, it stops the windows misting up, dries the car out..... Gives a better air quality to my mind.....
I'm just wondering whether everyone leaves the automatic air re circulation on. Supposed to switch to recirc if pollution detected. Never used it myself....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #294240 19th Nov 2014 10:24pm
Keep mine on all the time.
Can't see why you'd turn it off to be honest. Got - 2017 SDV8 Autobiography in Loire Blue
Post #294248 19th Nov 2014 10:56pm
There's an off button..... Shocked
Leave mine on all the time, no good reason to turn it off, keeps the seals lubed up and the refrigerant circulating. There is nothing that can't be fixed with a hammer😜😜
Post #294250 19th Nov 2014 11:07pm
JAYBOY
Can you turn it off then Laughing Laughing 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #294251 19th Nov 2014 11:08pm
mjdronfield
To add balance, it does dry the leather out though, which gives you an excuse to rub all that lovely conditioning cream back in..... Laughing 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #294252 19th Nov 2014 11:10pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Another for leaving the air con on Thumbs Up , I did with the land cruiser before hand but not with the D1......and lost all the gas!
The b Censored x they say in switch it on at least once a month is utter rubbish..... but of course its not if you like getting the spanners out Laughing If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #294254 19th Nov 2014 11:25pm
Always leave the A/C on and use AUTO setting. Just adjust the temp with the temp dials. This is how the car likes it and keeps the electric dry due to it dehumidifying effects. Its AIR CONDITIONING not Air Cooling. Thumbs Up
Post #294263 20th Nov 2014 12:15am
Page 1 of 4 1234>
