Home > Technical (L322) > 3.6 TDV8 EGR options?
Page 3 of 5 <12345>
Mikey
Cam-Tech-Craig wrote:
Dave, firstly welcome sir Thumbs Up
Secondly, i do NOT know of anyone that has managed to blank TDV8 EGR's yet sir. They are electronic so cause all manner of faults just blanking them... They need mapping out too...
So, unless your Dad has a strange obsession with watching his money go up in almost the same amount of smoke that will come from the LH exhaust... My advice is to resolve the issue immediately sir...
Alive Tuning, for one can map out TDV8 EGRs Thumbs Up
If you are familiar with mapping software, it's not a huge issue to overcome.
The issues lie I making sure your work is not copied by Joe Bloggs Thumbs Up
Post #294414 20th Nov 2014 7:37pm
Ziggy
Australia
Ok So this might be a dumb question isn't the egr on a TDV8 the same as one on a TD6? i.e. the computer tells a gizmo when its time to open the egr the gizmo sends a signal to a thing-e-mebob and the thing-e-mebob sends vacuum to the egr opening the valve into the inlet manifold
I only bring this up because on my TD6 I blocked the vacuum pipe there by stopping the burnt exhaust gasses
re entering the combustion chamber
have I done wrong ???
Ziggy "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #294492 21st Nov 2014 9:46am
Mikey
Bit more complex on the TDV8 Thumbs Up
The valves are electronically controlled by the engine ECU. When the valves are opened, the management is expecting to see a drop in airflow through the air flow meters, as it shuts the butterfly valves on the throttle bodies, to "suck" the waste exhaust gas through the EGR.
This is due to emissions regulations, with the TDV8 being an EU4, and the TD6 being an EU3
In addition to this, due to EU rules, EU4 engines MUST display a warning if there is an issue with the emissions control system. This was not a requirement on EU3
Post #294494 21st Nov 2014 9:52am
Ziggy
Australia
Mikey Bow down
Cheers cobber so we have Brussels to blame again..............
Why cant they keep things simple
Zig "Those who cannot remember the past are condemned to repeat it."
George Santayana
Post #294526 21st Nov 2014 12:58pm
SteveMFr
Site Sponsor
No. A warning light does not a complex system make. And emissions tightening standards is only sensible.
And, though advancing technology makes reducing emissions even further a possibility, the un-robust EGR system on the TDV6/8 is a JLR specialty.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #294540 21st Nov 2014 2:27pm
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
On the point of blanking the EGR with plates, we have done this in a few local TDV8 3.6 without deleting the EGR duty cycle in the map, and have had no DTC come up
Perhaps the software is different between UK and ROW vehicles?
Post #305698 16th Jan 2015 11:31pm
So, does mapping out the EGR valves cause emission problems at MOT time? Got - 2017 SDV8 Autobiography in Loire Blue
Post #305702 16th Jan 2015 11:55pm
Baben
We don't have such a thing as an MOT here in Africa Smile
I assume that question is not for me
Post #305713 17th Jan 2015 1:37am
No, just to the thread Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #305717 17th Jan 2015 1:58am
Ziggy
Australia
Yes Yes Yes.......someone who thinks like me, if you blank the port on the inlet side of the valve the actual valve would open (ecu's doing its thing valves opening ecu thinks everything is ok) but the burnt gas is not returning to
the inlet chamber..........as to UK and ROW cars after exploring the CCF on a UK car everything is there to change it to a AU configuration on the audio and TV side of things any way the venture cam was also there but turned off all you have to do to get it working on a car that came out of the factory without one is turn it on in the CCF, so I would guess there is no difference in the programs only in the way they are set up
Did you notice any improvement after blanking them off??
In respect of the MOT I would say not if the motors ruining well it will pass an emissions test with the EGR blanked
George Santayana
Post #305718 17th Jan 2015 2:13am
Mikey
My D3 passed its latest MOT with no EGRs and with no Cat Thumbs Up
Post #305740 17th Jan 2015 10:05am
Bet that smells like an old ice cream van doesn't it? Removing both the EGR & Cat makes them stink!
Post #305744 17th Jan 2015 10:15am
Mikey
It doesn't smell nice Laughing
Made all the difference to the way it drives though. Even those with *highly recommended* remaps can't keep up with mine Mr. Green
Post #305754 17th Jan 2015 10:29am
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
Over to you Craig yours takes some beating Thumbs Up
Post #305790 17th Jan 2015 11:51am
Mikey is referring to a 2.7 tdv6 Disco Scott... So no comparison to a tdv8 FF my friend...
Post #305802 17th Jan 2015 12:46pm
Page 3 of 5 <12345>
