Home > Maintenance & Mods (L322) > spark plug schedule on 2006 ajv8 ?
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
as the title states trying to find the service schedule for the 4.4 ajv8 jag engine ffrr. i have searched a fair bit and can't find when the spark plugs are due to be changed ?
Post #294922 23rd Nov 2014 11:04pm
105K or 9 yrs from memory... Thumbs Up
Post #294934 23rd Nov 2014 11:51pm
markcaughey
Thanks . Also how often should the diff oil and transfer box oil be changed ?
Post #294945 24th Nov 2014 1:47am
I change my own every 30K or 3 years Mark and check it 12 monthly... I think from memory the book says 80 or 90k... A tip would be to take the drain out slowly and let a small amount run into a white aerosol lid so you can inspect its colour/degradation and if its clean just check the fill level Thumbs Up
Post #294946 24th Nov 2014 1:57am
p.s. the rear diffs on your model tend to condensate terribly which rusts the diff/driveshafts and creates great expense! Rolling Eyes
Post #294947 24th Nov 2014 1:59am
Mikey
Spark plugs are 105k/7years
Diffs and gearbox are all 10 years/150k (which is madness. You want to do them every 5 years/75k)
Transfer box is 75k/5 years
Post #294952 24th Nov 2014 7:41am
markcaughey
Thanks .
Post #294953 24th Nov 2014 9:46am
Im starting to feel like I'm being "stalked" Rolling Eyes Yawn
Laughing
Post #294955 24th Nov 2014 10:15am
markcaughey
is there a diy/guide on here for doing it ? or how much is it likely to cost from my indy ?
Post #294965 24th Nov 2014 11:27am
dont know about a guide for stalking but have a look in the wiki for the gearbox stuff etc.. Wink ... - .- -.
Post #294967 24th Nov 2014 11:36am
markcaughey
found a guide for the transfer box oil change, looks easy enough. i noticed its on a td6 though will that be the same as the 2006 ajv8 ? can't find any guides on changing the diff oil but I'm thinking its much the same ? drain bolt and fill bolt etc
Post #294969 24th Nov 2014 11:54am
found this using the search function. its for a td6 but i'm sure its the same for yours..
http://www.fullfatrr.com/forum/topic25909....g+diff+oil ... - .- -.
Post #294970 24th Nov 2014 12:00pm
One thing to note is that the diffs are a specific quantity of oil, not a fill it till it runs out job. At least it is on mine...... There is nothing that can't be fixed with a hammer😜😜
Post #295011 24th Nov 2014 6:16pm
Rolling with laughter Rolling with laughter Rolling with laughter Thumbs Up
Post #295057 25th Nov 2014 1:17am
