Home > Technical (L322) > non starting primary4.5 bar fuel rail 80 bar ,cars for sale
Page 1 of 3 123>
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
on way to work this morning 03.30 hrs the Censored decided to throw a wobbly fuel pump seems to of packed up the one in the tank aa agents turned up within ten mins!!!! with flat bed and recoverd me to just round corner from house couldent get wagon down our road for the cars parked (nob heads)
thing is only did the pump in April so not a happy bunny.
dtc 1255 fuel low pressure sensor
pre supply press 1.0 bar actual rail press 0.0 bar
when cranking pre supply pressure 2.1 bar actual rail press 10.2 bar have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295119 25th Nov 2014 1:25pm
ebajema
Sorry to hear that mate, always annoying if this sort of stuff happens but even worse that early in the morning.
Looking at the situation, before you change the pump (it shouldn't fail this quickly after being replaced). I assume the external electric pump has already been replaced (recently) as well ?? So both pumps are relatively new ??
There are potential other issues, connectors/wiring on sensors/injectors etc. I remember reading something on wiring being damaged on TD6 models causing similar fault codes. The fuel pressure sensor could have gone etc.
Unfortunately the fault codes are not necessarily giving the direct cause sometimes. A good indy should be able to find out what is really the problem.
Hope you get it sorted soon and that you can enjoy it again Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #295125 25th Nov 2014 2:08pm
Re: I hate this car
Did you fit a genuine LR pump or aftermarket pump?
Have you changed the fuel filter?
Post #295130 25th Nov 2014 2:24pm
trainmanone
both after market ,prob I have at min is the aa agents couldent get down my street so left car round the corner the aa have agreed to come back and move it to out side my addresss later today between 1800 and2000 only needs moving about 150 yrd lol have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295131 25th Nov 2014 2:34pm
trainmanone
car outside house , so will have to look at it later in week as no time for next couple of days . have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295218 25th Nov 2014 9:58pm
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Not good when this happens at silly o clock, hope you sort it.....match normally works Laughing If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #295221 25th Nov 2014 10:14pm
trainmanone
any ideas as to where to be looking ????? have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295336 26th Nov 2014 8:17pm
trainmanone
found out what the dtc 1255 refers to its the sensor on top of the fuel filter.
tried purging the system and its full of air bubbles bad smell of diesel and looks like diesel on road under rear of engine,so I have a leak
so now thinking the leak is my problem ...........
could it be an injector as there was a fault before this happened "smooth running regulator"
any ideas have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295368 26th Nov 2014 11:46pm
trainmanone
bump Whistle Thumbs Up have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295519 27th Nov 2014 8:24pm
sounds like it is sucking air into the system, if this is the case you will have all sorts of problems. But should be fairly easy to fix. probably a bust pipe somewhere. get under the car and have a look.
in theory the leak should be before the LP pump, as otherwise it would push derv out not suck air in.
fuel lines pic on here to give an idea what you are looking for.....
http://www.fullfatrr.com/forum/topic24638....+fuel+pump There is nothing that can't be fixed with a hammer😜😜
Post #295523 27th Nov 2014 8:26pm
trainmanone
thanks northern will look over weekend ,shifts this week don't help lol have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #295525 27th Nov 2014 8:32pm
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Trainman, who do you drive for...?
I'm ex EWS/Freightliner. Now with GBRf. Very Happy
Post #295526 27th Nov 2014 8:51pm
You've probably been past my house a few times then, always have ews and freight liner trains coming through as I live on the freight line just south of derby! There is nothing that can't be fixed with a hammer😜😜
Post #295527 27th Nov 2014 8:55pm
Mark L
I'm guessing you live between Stenson and Chellaston then? Wink
I've been over that way all week learning new routes for a contract that kicks off in January.
Post #295528 27th Nov 2014 9:00pm
slightly east of chellaston Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #295530 27th Nov 2014 9:15pm
Page 1 of 3 123>
