Home > Maintenance & Mods (L322) > Did the "full air treatment" and...
Weegie
Fitting the upgraded crankcase breather is perfectly straightforward. Remove the covers, unbolt the old and bolt on the new. John
GAP iiD BT-Sold
Post #293979 18th Nov 2014 6:54pm
J. C.
Italy 2002 Range Rover HSE Td6 Ipanema Sand
Uh-oh, car doesn't heat up properly... Roberto
_________________________________________________________________
2002 L322 TD6 HSE in Ipanema Sand with "suicide charcoal" interior.
Other current cars: 1990 MB R129 300SL-24, BMW 118d E87.
Previous cars: '87 Mitsubishi Pajero, '96 Lancia Dedra SW, '91 Lancia Delta Integrale EVO, '01 MB CLK 200k EVO, '03 MB R230 SL 500, '99 Range Rover P38 4,6 HSE.
Post #294695 22nd Nov 2014 3:03am
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
did you end up having an issue?
Post #295121 25th Nov 2014 1:38pm
J. C.
Thermostat not working correctly. Car's being fixed right now. No other issues reported.
Besides that, everything's ok and I can only recommend these simple mods. The only downsides are the turbo spinning and releasing like my old Lancia Delta EVO and the higher induction noise, which is frankly irritating.
Must start thinking about placing some sound deadener around the airbox... suggestions? Roberto
Post #295133 25th Nov 2014 2:38pm
J. C.
Quick update: couldn't stand the extra induction noise any more, therefore I bought a standard Bosch air filter and replaced the performance one.
Car is quieter, no discernable differences in performance or MPG. Roberto
Post #302815 5th Jan 2015 9:13am
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Hi all
Is the extra noise that bad?!
Im just in the process of doing the EGR, Breather and was going to go Green Cotton filter (The Air filter is the only part i havent ordered yet!)
One of the other guys was saying the Bosch filters are well adaquate, but i was thinking the Green Cotton would play quite a part in the performance and mileage gains?
If its really that bad, i may have to go Bosch filter too!
Cheers Accept, some days your the pigeon, some days your the statue!
Post #302829 5th Jan 2015 11:53am
The noise being described from the turbo when you back off, and sometimes when the car changes gear is the turbo stalling. When you are driving the turbo is spinning at 200,000 revs or whatever it's speed is, when you back off or change gear the throttle is closed shut, the pressure created by the turbo has to go somewhere and the place it used to go, through the egr, is blocked. The pressure then goes backwards through the turbo and stops it dead.... This can have significant impact on the life of the turbo... if it is doing it all the time you need a blow off valve (dump valve) to release this pressure safely. If you fit one it has to be matched to the turbo size and speed, don't just use a generic one, get the correct one from a specialist... Pete
Post #302858 5th Jan 2015 2:43pm
