![]() | Home > Technical (L322) > Is this the best battery for 2010 3,6 TDV8? |
Seabass Member Since: 05 Feb 2014 Location: Värmland Posts: 88 ![]() ![]() |
Hi all, been searching and reading several battery related threds on here but to be sure is this the right battery and will it fit in my TDV8?
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16343 ![]() ![]() ![]() |
Has your vehicle had the JLR update to a "Glass Mat Battery"? sir
ksskaret Member Since: 27 Oct 2013 Location: Tromsø Posts: 73 ![]() ![]() ![]() |
I replaced My genuine LR battery with Odyssey PC2150S. A perfect battery for cold climate and a high electricty consumption.
No sir, I don't think ever was an recall on that I Sweden or so I'm told ![]() Edit: Got an answer from LR Sweden now and that q159 was not for my car but for a number of cars produced between specific vin numbers. You being an experienced professional, will the battery on my link fit in the car Craig? 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto Swedish LR club member #5333 Last edited by Seabass on 26th Nov 2014 1:15pm. Edited 1 time in total |
So.. Ordered this battery and I will make it fit |
It should fit, just make sure you have NO WIND when you put the bonnet in access mode and clean out the battery tray area as well. Also dont drop a bolt down there or you may never see it again!
I will make sure, only use the park heater sir. 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2280 ![]() ![]() ![]() |
Guess don't have beans for breakfast that should solve the wind probs |
Bryan N Member Since: 01 Jan 2014 Location: Cambridge Posts: 68 ![]() ![]() ![]() |
Just for future reference, Service Action Q159 - the factory recall to correct a software fault and fit a different battery - only applied to the 2010 MY 3.6 TDV8 between VIN LM306631 and VIN LM334416. That Service Action expired(!) on 30th September 2014 so I'm pleased I discovered last December that the dealer who sold us the car had 'forgotten' to do it! ![]() |
In your climate I'd be tempted to do the Dan method and stick a battery in the spare compartment at the rear as well unless you've had the recall that borks the fbh to only run 15mins |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
with ref to the spare Battery compartment in the rear, where is it? do you have to run all the wiring through from the front battery to put them in parallel or is some of it part wired?
The spare battery area I refer to in the rear is an area that's been found to take a normal average sized car battery with very little modification.
So I replaced the battery today, it was tight so I had to rebuild the positive fuse connector to be able to connect the positive clamp due to the oversized battery.
thank you will look at info, was thinking smaller battery there that i could put an inline feed on to select when to use it. the leisure battery will take a harder kicking down on power and will recover. Someone far more knowledgeable than me on the subject suggested the make up of Leisure batterys means they work as std battery too and can take greater discharge. i run a tractor, 3 x 90s, a 110 on Leisure battery and have done for a considerable period of time. seems to work well for me so made sense to put the RR on one too. Cheers James |
