![]() | Home > Technical (L322) > Air suspension compressor.. are there different types ? |
| JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565
Hi, the air suspension compressor on my car has given up so i thought rather than mess about with it i would just order a new one from island 4x4 It turned up today , i just removed everything from my boot and its different to the one currently in my car.
| Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2287
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
Although your car is an '05' it must be a MY2006.....that explains the difference. Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
| rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496
55 plate is around the change over, my 55 plate is an 06 model with the facelift and touchscreen (AJV8 engine as well but see you are diesel so i think the engine did not change). If you have the facelift smaller one piece lights and grill and touchscreen you will have the 06 model. If you have touchscreen and the bigger two piece lights then it is a changeover model using some BWW and some Ford bits so not as clear which model to choose for parts etc. There is a difference between knowing your sh!t and knowing you're sh!t
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669
Hi ya bud, think you might have the wrong unit, I think that 2005 was the change over year, if your compressor has the 2 blue pipes then it's a Hitachi unit not the Wabco that's in a round dome like container for up to chassis number 5A999999. The Hitachi unit goes on chassis number 6A00001 on wards.
Thanks for your great advice is much appreciated, i just checked my vin and it is a 6A------- Teach me not to check the item i'm changing first |
Sorry Bud, but I'm not in a position to answer that one, as I have the Waboc unit. However I will say that if the Hitachi is anything like the Wabco, it will only have a small piston whizzing up and down frantically trying to keep up with the pressure demands of the suspension. If you use the low exit button or regularly go in to off road mode, you is going to ware it out quicker. Having said that just going over 60 Mph will cause the car to lower it's self, and therefore will require air to return to normal height. Then there is the well sealed nature of the air suspension, is it any wonder that the compressor gives up?
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
Just went through something similar with my mum's new (to her) RRS SC, as the compressor had gone.
Are the ones from LR not Hitachi also then mate? |
Not sure, I never saw the unit Discovery 4 HSE
Yes they are, Hitachi are OEM for the later FFRR's Yesterday I couldn't spell Engineer... Today I are one!
Hitachi were dropped by Land Rover in favour of another manufacturer (three letters, but i cannot remember at this time of night what they are)
| All times are GMT |
