Home > Technical (L322) > remote keys
stcstc31
Ireland 2005 Range Rover SE Td6 Atacama Sand
remote keys
so this morning. go to the car, its 0 degrees
key was intermittent both opening and locking the car
grab the spare key and it does the same
drive to the office (only 5 or 10 min drive) and it does it again
is this something normal, ok i know it shouldnt do it. but is it something to be expected
Post #295421 27th Nov 2014 12:09pm
Battery sound low , not uncommon for the rolling code to get a bit lost with lack of volts . 2008 MY Supercharged
Post #295427 27th Nov 2014 12:40pm
stcstc31
ah ok. looked at diagnostics and says 11.5 with everything off
maybe time for new one
Post #295432 27th Nov 2014 1:20pm
stcstc31
so i ring the indie, explain what happened
he says nah cant be the battery the car started
Post #295608 28th Nov 2014 10:03am
He's a genius..... Censored
A low battery voltage can cause all manner of gremlins in the RR that would otherwise make you Censored your pants. A new battery is a god investment. Discovery 4 HSE
Post #295610 28th Nov 2014 10:20am
stcstc31
thats what i thought.
cant be arsed to change myself so will go somewhere and get one
Post #295611 28th Nov 2014 10:32am
I'm afraid your Indi sounds out of his depth with Elastrickery , the car will start even when the ECU's have taken the hump over a he amount of volts available. 2008 MY Supercharged
Post #295817 29th Nov 2014 1:11am
