![]() | Home > Technical (L322) > Gearbox Oil Leak - 4.4 V8 |
Stoich Member Since: 21 Dec 2009 Location: Stornoway Posts: 36 ![]() ![]() |
Have oil coming out from inspection rubber on bellhousing (2002 4.4 V8 ) Was the occasional drip but is now losing level due to increase in leak, dripping every time I stop even if for a short period, have topped up with about a litre of oil.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1021 ![]() ![]() |
If you’re sure that it’s transmission fluid leaking out then the input seal would be the obvious culprit.
Thanks Phill
Question for RR Phil
Tell them it’s the ‘F38’ torque converter. The same one was used in the 4.4 V8 BMW E53 (X5) with the M62 engine. Anything else won’t fit. For example, the 4.6is X5 with the 5HP24 uses the larger L51 unit.
Thanks again RR Phil, you're knowledge on here is much appreciated |
The saga continues.
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Hi mate,
Thanks Jake
Lrdaft, I'm assuming you are Barry from Mann Automotive. Can't fault your work in anyway mate. As said in previous post fault was diagnosed by Inverness 4x4, who didn't want to take on job. Incidentally, I'm gonna get another oil cooler. Does the oil need to be drained or can the job be done while keeping most of oil in gearbox.
Trossachsturbo Member Since: 29 Jan 2014 Location: Central Posts: 24 ![]() ![]() ![]() |
I had exactly the same have you thoroughly checked both of your camshaft cover gaskets, sometimes referred to as rocker cover gaskets?
Getting a shot of a boroscope later today, impossible to see at present with vent panel removed.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
if you are leaking engine oil from rocker gaskets (at top), into the gap between the heads, (around the water valley cover....the path out, is through the gearbox bellhousing. look at this youtube... If you go to around the 3 minute mark, here.. you will see the inlet manifold off, and there is a hole to drain the area through said bellhousing. that's water or engine oil. it will drip out bottom of gearbox. easily hiding/masking it as a gearbox leak. that's if its not if the said hole is blocked with dirt/grease. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Stoich
