I built a 9m by 3.8m (ish) thermo block workshop to have the allowed 30 square metres (internally measured) in my garden, and 4m roofline, for £5000 ....using 6 cubic metres readymix, pumped in for the base. 550ish 9inch blocks, I had a brickie in for a few days at £600....then, ebay for new patio doors, windows and s/h marley interlock roof tiles (@17degrees) parquet flooring, etc. rendered in/out and plastered/roof lagged/wired/painted
its full of my stuff..its a workshop come den. though I bet I'm on the council 'shedroom' radar but all above board etc.
if you are set on a prefab, look on ebay, they come up. consider the milage! avoid asbestos roofs!! you will need to hire a 7.5ton lorry though (normal licence). at about £150 a day. a decent raft base will be around the £1000 mark like mine was. (£100 rebar, 700 mix, (that's a proper mixer, not the man with shovel and onboard etc) + £250 pump.) took 1hr from doorbell ring, to pour, pump, tamp, clean-up.
