![]() | Home > Maintenance & Mods (L322) > Won't start when hot...sometimes...!!! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
From what I gather people, it's not a fueling issue, it's an issue that's causing the engine not to turn over at all. Or to put it another way the starter motor is not seeing the input from the key. If it's only happening when the car is hot then it might be moisture related, this would then point me towards the starter relay, as it would function better when its cold if the terminals inside are carbon-ed up due to arcing. Could also be caused by a temp sender giving a high reading and the ECU not allowing the engine to start, but I imagine that if this was the case you'd get the Bong of death followed by the message of Doom! Yesterday I couldn't spell Engineer... Today I are one!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8709 ![]() ![]() ![]() |
Thanks for all the thoughts guys,
Just had a thought |
Cheers mate and, yes it's an easy thing to do if you can get to the connection on the starter motor, you can't even see the motor from above and below it is covered by a massive heatshield as it's inches from the exhaust and you can't see much of it either, the connections are on the inside of it against the engine to keep them out the way... so an easy job turns into a right PITA...
Just took the old starter apart and it looks like it is actually sealed up pretty well, the drive pinion, when stripping it looks to be sealed as well, so the only way water can get in is through the vent hole on the top which is connected to a tube that exits at the top of the engine near the bulkhead, maybe this pipe has a split in it somewhere or has just got old and leaky.... If water gets into the main body there is a path through to the solenoid so maybe this is the problem, it's regularly been underwater with the old one and the new one so the problem could be water ingress...
Recon you've solved your own problem there |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7956 ![]() ![]() ![]() |
That's like trying to explain to a Labrador that it can't jump in the water after the stick...... |
Are you suggesting that we should call him Labrador Pete? |
Maybe you should make your Hang Over look more like this one
