![]() | Home > Maintenance & Mods (L322) > Water Pump and Thermostat Failure on TD6 (BMW M57) |
| bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 88
Strip Down -
Timing Cover Patch Up -
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35877
excellent , thankyou |
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Wow. I've not heard of this type of failure before. |
would it be a m54 in aussie land? or is it defo a m57..... ... - .- -.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
Nice write up, my guess would be the seized up fan, they tend to seize off center so you have a large imbalance in them, this is enough to rip the water pump to pieces.
And AFAIK they never fitted the M54 to a Range Rover, it's virtually the same engine as the M57 but I'm pretty sure all Range Rovers just had the M57...
Forgot to include the all important failure picture -
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
I'm surprised the belt tensioners and pulleys were in good order, the bottom tensioner is common for failing and I've changed the top one on mine because of a rumbling bearing |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Typical old fella got pensioner on the mind hey John 😜😜 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Fecking Safari spell correction, I need to switch it off |
Absolutely! I've nearly thrown my Mac across the room.
Def a M57. M54 is a 6 cyl DOHC petrol motor. Not that important, but if it is to be a reference, then people ought to be able to find it with a search.
RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
A tensioner on a pensioner...
Looks like were doomed, The tick box for spelling is greyed out so I can't change it |
| All times are GMT |
