![]() | Home > Maintenance & Mods (L322) > Td6 viscous fan removal.. |
Does your aircon work? If so, remove the viscous for the winter... The aircon fan works when the temps go up BUT... ONLY if the aircon works |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7995 ![]() ![]() ![]() |
Has it got a performance air filter? If so, there is quite a bit more induction noise when accelerating.
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Hi guys, yes my air con works a treat and leave that on all the time. Im sure it must be the viscous fan making most of the racket i think next week i will have a go at getting it off and then see if its any better without, will perhaps do a coolant change and flush at the same time so that i know its done then.
If it sounds like a small airplane engine then the viscous fan has likely locked up as the unit fails.
Cheers buddy, I have some fan spanners so will whip it off at the weekend and see if it is knackered or not. |
Naki Member Since: 04 Feb 2021 Location: Boston, South Lincolnshire Posts: 34 ![]() ![]() ![]() |
I recently purchased a 03 TD6. I have realised a previous owner had already removed the Viscous Fan on mine.
chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 477 ![]() ![]() ![]() |
I had owned my old 4.4 V8 petrol for a few years before I realised that the viscous fan had been removed by a previous owner |
Interesting. If anything I would think a petrol V8 would need one more than anything?
Yes, all year round for 9 years with no issues as a result. Very little towing until the last couple of years when it pulled an Ifor horse trailer a couple of dozen times but still didn’t throw up any problems. Perhaps I was just lucky |
Ok, that’s good to hear.
A bit of both winter and summer but mainly good weather. In the time I had the cari don’t think the temperature gauge moved any higher then the middle point. As I said, I may have been very lucky so don’t take it as a recommendation as the fan is there for a reason - it just wasn’t on my car |
I was wondering how common it was that people removed them. I guess the fact there’s forum posts on if, relatively common?
