Home > Maintenance & Mods (L322) > Heads up for discovered subframe rust
Mark L
United Kingdom 2010 Range Rover Vogue SE TDV8 Ipanema Sand
Thought I'd give a heads up for some serious rust I've discovered on the subframe last month, as others may want to check theirs.
Vehicle is a 2010 model.
Whilst carrying out a full service and upon removal of the front plastic underside tray, I discovered a build up of crud trapped in the corner of the frame where one of the securing points for the tray sits.
Pic taken after the muck was cleaned out:
A close up:
I wire wheeled as much as I could get to before painting over again:
Admittedly, it was a quick, temporary job, as time wasn't on my side that day.
The other side also had a build up but it hadn't started to rust heavily like the this side had.
I've only had the vehicle for a year, and I know it hasn't led an off road life prior to this as the underside was only showing the usual tell-tale signs of normal road use.
So has anybody else come across this problem?
Post #297523 7th Dec 2014 5:47pm
My '02 wasn't that bad when I cleaned it up, wire brushed, rust killed and hammerited in the summer, but the original paint was coming off in most places. .
Post #297597 7th Dec 2014 11:13pm
Mark L
It just really surprised me, as the rest of the underside is mint.
Post #297601 7th Dec 2014 11:24pm
The later the cars the worse the rust issues imho... I think Ford must have changed steel suppliers or their dipping process as all 07my> (interior facelift models) rust much quicker than the BMW built earlier cars... Rolling Eyes
Post #297608 8th Dec 2014 12:56am
Mark L
We'll I've cleaned as much as the underside as I can reasonably get to in order to give it a fighting chance for the future.
Post #297816 8th Dec 2014 11:00pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Wire brushed and painted my sub frame this summer, surface rust really.
Post #297818 8th Dec 2014 11:07pm
