![]() | Home > Maintenance & Mods (L322) > Lubeguard & Dr Tranny |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 ![]() ![]() ![]() |
Thanks Ebejema will give it a go once I get the car back |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Eugene, once this is added do you let it self level by opening the filler on flat ground again or have it slightly over filled? Discovery 4 HSE
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Adam, i doubt there is much more than an egg cup if you add both additives... If just the "shudder fix" then not much more than a desert spoon full... And in all of those litres, it won't make any difference in volume my friend |
Like Craig says, it is very little volume you are adding so I would just put it in, close the plug and turn off the engine. MY 2010 5.0 SC Galway green and sand interior!!
Would this stuff help with the standard drivetrain shunt on changing down gears? Discovery 4 HSE
Added the Dr Tranny today so we'll see how it goes, will be doing a gearbox oil change over the Xmas break at a friends work shop |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
where can you buy this additive in the uk |
Your better off putting two tubes in a large gearbox.
Well I have done about 300 miles since I put the Dr Tranny additive in the gearbox, changes seem smoother and have noticed there is no clunk when putting it in reverse |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
Dr Tranny has sorted mine a treat, their looking to add this to all recon'd ZF boxes due to the rebuiled |
It's ordered, thanks NFDI for the link |
On the D3/D4 forum they add Dr Tranny via the front Gearbox Oil Cooler in minutes, can you access the TDV8 Oil Cooler or is it hidden and inaccessible. ? |
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Gary.
