Home > Maintenance & Mods (L322) > Water in the boot, help I'm drowning!
miggit
Hi all, just tried a search for water ingress in the boot, and I've lost the will to read, there isn't any definitive answers, all I can find is it happens and it kills the radio and sat nav. So far I've been lucky, but water is getting in and I'm looking for causes and fixes, before every thing goes pop in the boot!
After the downpour we've just had I'm now wondering if I left the radio switched on and if this is the last time it will work, I'm feeling a wee bit nervous about turning the key.
I have been considering taping up the sun roof, just to get me through the winter, but I can't see Land Rover running the drains in the rear pillars when there are closer routes to the outside world, B or C pillars.
Can someone how has found the cause and cured the problem, as to the wheel well becoming a real well, please put me out of my misery, before I start to Big Cry , and make things a lot worse Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #298324 11th Dec 2014 10:43am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
From what I have read about this on here and other forums, it can be from the boot seal ( more than likely )too how the FF has been welded in the back where the sat nav compartment is, too if you have a tow bar fitted !
I think there where some pictures on here about that compartment getting rusty, Joe90 im sure took some. If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #298330 11th Dec 2014 11:36am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
You need a water shedder!
http://www.fullfatrr.com/forum/topic8710.h...er+shedder 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #298331 11th Dec 2014 11:41am
You need a new upper tailgate seal. Thumbs Up
If you look at it with the tailgate open you will find that one or both of the top corners have come away from the metal flange it is supposed to sit on.
Rainwater then runs down between the body panels and usually exists just in time to dump on the DSP and the satnav.
It then carries on into the wheel well. You can drain the wheel well by removing a rubber grommet.
A water shredder helps "a bit" but doesn't solve the water ingress problem.
Imo the tailgate door seal is badly designed and not fit for purpose.
A new seal solved the problems you describe for me.
Post #298338 11th Dec 2014 11:59am
miggit
Thanks chaps, just got to find a seal now before it all goes Pete Tong Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #298340 11th Dec 2014 12:03pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Will be the rear seal. Ours was wet in the boot and looked like it was coming in from the rear bumper area. Dried it all out, fitted a new seal and had a dry boot, radio area ever since.
Got mine from Dan.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #298363 11th Dec 2014 2:12pm
mjdronfield
It's prob seal as others have posted. If not, it's prob inside the spare wheel well behind where the bumper fits on, ie near your knees if you are stood at the back reaching in, if you see what I mean.
That's the 2 places that are discussed in the various threads.
I have the Land Rover official plastic bag fitted around the infotainment units, just in case......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #298404 11th Dec 2014 5:37pm
Paul
It get's in when you sit up to your door handles in a Welsh river Whistle Whistle Pete
-Click here for Thread-
Post #298421 11th Dec 2014 6:41pm
miggit
Bow down All Hail Poseidon Pete Bow down
I'm really Shocked to hear that water gets in when your up to your handles in water, what would happen if the water got half way up the screen Shocked Shocked You'd have thought that they'd have gone to Lotus and had it specked up to Rodger Moore's Esprit standards, they just don't build them like they used to Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #298431 11th Dec 2014 7:16pm
miggit
I've just had a thought Exclamation Ouch! Shocked Big Cry
Pete, sorry, Bow down Poseidon Pete Bow down, Do you think that there is any mileage in a FFRR bilge pump system? Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #298457 11th Dec 2014 9:40pm
mjdronfield
A V8 jet ski could result...... Whistle 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #298466 11th Dec 2014 10:10pm
miggit
I was thinking more along the lines of an under water viewing platform Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #298476 11th Dec 2014 10:28pm
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Got mine from Dan.
Steve.
Same here, tailgate seal all day long.... Thumbs Up Thumbs Up Thumbs Up
Post #298635 12th Dec 2014 5:47pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I chased a similar leak for ages, turns out it was coming in through the armature gaskets..... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #298722 13th Dec 2014 8:08am
Miggit,
Top left corner of the seal... If you feel both sides of the seal (the part that fits the bodywork, not the water seal itself) you should find the "clamping springs" aspect of the seal has failed. They get wet and rust, then expand forcing the seal clamping springs apart, opening up the "c" sectional part of the seal... This then almost certainly opens the white sealant inner bead up to the elements drying it out. This then compounds the issue!
Hope that helps explain in more detail Thumbs Up
Post #298733 13th Dec 2014 9:22am
