![]() | Home > General > How far do I need to drive? |
| RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724
If mine gets started it does a minimum of 13 miles (nearest civilisation) and neither this car, nor the D3 before, ever had low battery issues. Mind you, it'll do a 50 - 60 mile run at least once a fortnight so that may help |
| Bingo_123 Member Since: 19 Sep 2014 Location: Essex Posts: 176
there cant be a straight jacket formula. depends on multiple factors :
| NeinFondue Member Since: 05 Dec 2014 Location: Berkshire Posts: 22
I keep mine on a CTEK MXS5 battery conditioner as I don't do many miles and these cars have a lot of toys sapping power even after the car is off.. |
| Chillb Member Since: 25 Jul 2012 Location: Portsmouth Posts: 142
Was thinking the same too as I have started to use the remote heating most mornings for 5-10 mins and most of the time I only do 4-8 mileas a day however may do a 200 mile round trip every couple of weeks. Assume this also benifits the engine as it helps to get it to operating temp sooner. |
| JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502
the FBH works on heating the int if you use timed climate, unless it is <20deg C then it prioritises engine with some cabin heat.
| TheTowers Member Since: 07 Dec 2014 Location: SW England Posts: 4
I've always worked on 6 miles to recharge a cold start, but in reality, it's a length of string thing. Dont think it will be much less than that though. |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
I'd like to say I worked this out for myself but I haven't got enough fingers....!!!
