Home > Technical (L322) > No Electrics
zoso
Scotland 2013 Range Rover Autobiography SDV8 Santorini Black
No Electrics
Hi
Went to start the FF this morning and when I put the key in the ignition and turned it the car went dead......no lights, ignition, central lockng.......nothing - completely dead.
So I'm thinking it's a fuse that's blown ????
cheers 2017 4.4 TDV8 Autobiography
2016 4.4 TDV8 Autobiography - GONE
2013 4.4 TDV8 Autobiography - GONE
2010 3.6 TDV8 - GONE
2008 3.6 TDV8 - GONE
2002 3.0 TD6 - GONE
2006 Discovery 3 TDV6 S - GONE
2006 Discovery 3 TDV6 - GONE
2003 Discovery 2 TD5 - GONE
1999 Discovery 300 TDI - GONE
1998 Range Rover DSE - GONE
1997 Discovery 300 TDI - GONE
Post #298533 12th Dec 2014 9:31am
Sounds like a flat battery for whatever reason.
Post #298537 12th Dec 2014 10:01am
+1 for a dead battery.. ... - .- -.
Post #298539 12th Dec 2014 10:10am
If you're in the same part of Scotland as me, it was Baltic this morning, so a flat battery is most likely. Got - 2017 SDV8 Autobiography in Loire Blue
Post #298540 12th Dec 2014 10:23am
Weegie
I would think it's more dead than just flat. Worth trying a charge but modern batteries tend to die all of a sudden, especially when hit by low temperatures. John
GAP iiD BT-Sold
Post #298547 12th Dec 2014 11:04am
zoso
It was a brand new Varta battery that was fitted 2 months ago so I'll be diappointed if that's what it is Surprised 2017 4.4 TDV8 Autobiography
2002 3.0 TD6 - GONE
Post #298553 12th Dec 2014 11:33am
It's always possible one of the battery terminals has worked loose.
Post #298554 12th Dec 2014 11:53am
Weegie
Hope I'm quite wrong but if not it looks like a claim. It was just the suddenness that made me think.
Fingers crossed. Thumbs Up John
GAP iiD BT-Sold
Post #298555 12th Dec 2014 11:53am
zoso
I'll check the terminals are all tight when I get home from work. It was the suddeness of it that made me think it may be a fuse. I unlocked the car with the remote this morinig, got in (interior lights were all fine) put the key in the ignition, turned it and everyting blacked out - would a flat/nearly flat battery cause those symptoms ? 2017 4.4 TDV8 Autobiography
2002 3.0 TD6 - GONE
Post #298557 12th Dec 2014 11:58am
When you get home before trying to start the car switch you main beam headlights on.
If they come on and stay on for a couple of minutes without the engine on it's not a battery fault.
With a charged battery the engine should start, no fuses in the circuit to stop it.
From what you describe it does sound like a flat battery or a bad connection.
Post #298558 12th Dec 2014 12:04pm
Weegie
I thought from your original post that you had had nothing at all but if you had interior lights etc and it then went dead I would go with nicedayforit that it is a bad terminal connection which is reacting when you put the cranking load on it. John
GAP iiD BT-Sold
Post #298568 12th Dec 2014 1:03pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
+1 Weegie Thumbs Up
full story needed otherwise a diagostic reply may not be accurate
Post #298581 12th Dec 2014 2:24pm
zoso
To avoid any confusion I may have caused.......
1) opened car via remote - all normal, interior lights on etc
2) put key in ignition switch and turned to position 1 - dash showed "pre heating". Everything else okay - satnave monitor lit up etc.
3) turned key to start the engine - all went dark. No lights on dash, interior lights. key won't turn past first position and the remote no longer opens/closes the doors. That's how I left it.
That's what made me think a fuse had blown.
I'll check the lights when I get in from work as Nicedayforit suggested and if there is nothing then I'll assume the battery is flat.
thanks. 2017 4.4 TDV8 Autobiography
2002 3.0 TD6 - GONE
Post #298596 12th Dec 2014 3:27pm
Weegie
Put a multimeter on it. If it is showing anything round 12v then it's the terminal post connection. John
GAP iiD BT-Sold
Post #298608 12th Dec 2014 4:35pm
It will definitely be a bad connection on the battery from what you have described, don't just check if they are tight, they may very well be but a thin film will build up around the post and create a high resistance.
Take them both off, making sure the ignition has been off for five minutes, then clean the posts and clamps with some fine sandpaper, smear them with some Vaseline and put them back on making sure they are all the way down and do them up...
Sorted..... Pete
Post #298617 12th Dec 2014 5:38pm
