Home > Technical (L322) > Tdv8 window fault
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Tdv8 window fault
Any help would be much appreciated. My drivers door window has decided it no longer wants to function correctly, press the switch and it moves down about a centimetre and the stops and will go no further although it will go back up. Is there anyone had similar probs with a 61 plate SE. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #298927 14th Dec 2014 1:58pm
Is it not still covered under warranty sir?
Post #298929 14th Dec 2014 2:13pm
Might not do anything but try holding the lever/switch up for 10 secs, on the disco it resets the auto close so may do the same, worth a shot There is nothing that can't be fixed with a hammer😜😜
Post #298930 14th Dec 2014 2:20pm
Pfazz
It ran out on of warranty on 22/9 unfortunately 😢😢 Agueroooooooooo. 93-20
Post #298990 14th Dec 2014 10:55pm
Pfazz
I'm away until Friday so I will try the reset procedure when I get back, thanks. Agueroooooooooo. 93-20
Post #298991 14th Dec 2014 10:56pm
