![]() | Home > Technical (L322) > Dim sat nav and parkin sensors beeping.. |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Parking sensors - have you used a pressure washer on the car recently or are they very dirty or have you been through deep water?
PJS Member Since: 06 Jul 2010 Location: Yorkshire Posts: 506 ![]() ![]() ![]() |
The dirty parking sensors werent the problem. Anyone else? |
What year is it? Does the light flash on the parking sensor button when it beeps..... Land Rover Addict
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
you've probably done this already but,have you checked each sensor to see if they are all working...turn them on via the dash switch and listen to each sensor , each should make a ticking noise, if it doesnt then thats your problem.. ... - .- -.
