![]() | Home > Technical (L322) > Brake Fluid Change |
Gents (&Ladies...)
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
When replacing all my brake pipes from ABS to wheels, I only used @ 1.5 litres to refill and bleed (quite extensively!) IIRC.
Ahhh so if i nose about in the Faultmate MSV i could probably force the ABS pump to activate and kick in... that might be worth looking into tomorrow then and get it flushed out.. I need to check the parking sensors as well so could get this done easily enough. May just get 2litres then as 5 seems a bit excessive then lol FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1394 ![]() ![]() |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Or DOT 5.1, it's a higher specification - higher temperature resistance. - Usually more expensive, but sometimes you find deals where it's cheaper. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1527 ![]() ![]() |
I have *EDIT*LIES, apparently it's not 5.1!!**- ATE Superblue fluid ready to swap mine when I get round to it.
mat777 Member Since: 06 Apr 2015 Location: Nantwich/Liverpool Posts: 139 ![]() ![]() ![]() |
Hmm, that sounded intriguing.
I suppose it depends on what they put in it to make it blue. If it's some ultra toxic chemical, it's more likely the chemical has been banned generally, rather than the brake fluid specifically.
Gosh you're right. it's gone.
Couldn't you just add black food colouring into the tank before a flush to show when it changes? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Yes I guess that would work, as any reduction in boiling point would only affect the old defunct fluid.
Simple man = Simple solutions.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8714 ![]() ![]() ![]() |
I've always found that the old fluid goes dark anyway so it's easy to tell when the new stuff comes through.... Pete
Shouldn't do, there's no brake fluid check on the MOT other than for leaks. If the tester notices the level is low he or she might give you an advisory. |
