Home > Technical (L322) > Fan not blowing on auto, but works on all steps in manual?
Seabass
Sweden
Hello guys.
I tried searching but only found Fsr problems and since my fan seems to be working perfect on all steps when I put it through the manual steps this can't be fsr right?
If I start the car and have it in auto mode I can't hear the fan nor feel any breeze coming through any vent even if I drive it til the engine is normal temp.
It did not do this until afew weeks ago, normally it blows hard until the car is warm inside.
Any info/help on this is greatly appereciated.
[/img] 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Swedish LR club member #5333
Post #299859 19th Dec 2014 4:57pm
is the temp set high enough for the auto to kick in.. ... - .- -.
Post #299918 19th Dec 2014 8:05pm
Seabass
Sweden
Yes, inside is on 22c and outside is -2c 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Post #299941 19th Dec 2014 10:38pm
supershuttle
Mine doesn't light up on auto but I think it does the blowing job - ohh err missis Very Happy Geoff
Post #299960 19th Dec 2014 11:42pm
Seabass
Sweden
Well well, It seems the old FF mended itself overnight, today it works as it should again, are these the best cars ever built or what! Rolling with laughter 2010MY TDV8 Vogue Nara bronze / Arabica, Ivory. VW Amarok 2013 180 auto
Post #300268 21st Dec 2014 6:47pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
It is programmed not to blow air until it has reached temperature. Mine does the same...it's so you don't get even colder!
Post #300342 22nd Dec 2014 7:21am
ebajema
I remember that as well what AB just said, it waits for sufficient warm air / coolant heat is available before starting the fan. Keep an eye on the engine temp vs. the starting of the fan in auto Smile.
Do you have a stand still heater installed as well, I mean the "cold country electric heater" and is it a electric fan in the interior or also an engine coolant heater type ?? MY 2010 5.0 SC Galway green and sand interior!!
Post #300348 22nd Dec 2014 10:10am
