![]() | Home > Maintenance & Mods (L322) > interior boot light switch ? |
take the bulb out or replace with leds which dont take a lot of current.. ... - .- -.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
They will turn them selves off after about 30 minutes, at lest mine do, then providing you don't open / close any of the doors it will stay like this. Immediately something changes, ie, door opened they come back on |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2590 ![]() ![]() ![]() |
Hoovering the boot, you guys crack me up. Let it age gracefully |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1671 ![]() ![]() ![]() |
is it just a straight swap? 405 AB exec seats Baltic and Cirrus 93 RR Classic efi Remember it's easier to get forgiveness than permission! Gone in order: 4.4 TDV8 SE - gone to a good home 93 Classic hard dash Plymouth Blue 03 L322 Oslo Blue 2000 Disco TD5 ES Epsom Green 98 P38 Rioja Red 89 Classic Cairngorm Brown |
Yes provided you get the right type led |
Thanks Miggit but you have lost me. I'm only a lowly Architect not a sparky. What do you mean start the car and see?
I mean remove the bulb that you are planning to replace, start the engine and see if you get the 'Bong' of annoyance and the screen of Doom telling you that you have a bulb out! If all is quirt then you'll be good with those bulbs, if you get the Bong of annoyance and the screen of Doom then you'll have to find Canbus no fault bulbs, they are out there!
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
AFAIK the light switch is part of the lock latch on the upper tailgate
Are but if you were feeling super lazy you could just push to boot button on the key |
Even more simples.... |
I used my IID to turn the car lights off when the boot is open , if you cant do this then hold the interior light switch in the car for ten seconds and this will temporarily turn the lights off with the doors open then the you can put on you little french maids outfit and hoover all you want and the car will just go to sleep ( ahh bless ) |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Hold the centre switch in the front light for 10 secs... Disables the int lights completely... Opposite re-enables them |
Hoovering in the dark? Your a kinky lot |
