![]() | Home > Wheels & Tyres > Tyre wear |
Take it back to where you had the tracking done , because thats not good . 2008 MY Supercharged
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Have you had the rear bushes looked at for wear? They could be very worn and out of alignment when driving, but in true when resting on tracking machine. There was a posting recently on a Diy repair to show the bushes. They can be a right wot sit to remove. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
They look like 20" Toyo Proxes? Never heard a good word said about them in 20" I'm afraid Steve... (22" Toyo's are excellent before i get shouted at)
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Upper and lower rear hub bushes and perhaps control arm too, then 4 wheel alignment again. Sorted it for me after I had gone through two tyres, I got down to the belts first time round before spotting it! oh, do both sides for good measure, then you know where you are. Howto on the wiki if you like the spanners. .
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
100% rear bushes.........don't ask me how i know |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 ![]() ![]() ![]() |
Cheers guys. In tomorrow new tyre then check the bits as recommended |
Depends how |
Well... new tyre fitted, only to find out one of the front ones is bigger than the rest |
Don't wait too long before you sort out the bushes, otherwise you'll be in for another new tyre! .
or even TWO tyres! and a remaining wobble.
