![]() | Home > General > test drove a 5.0 |
It's the same gearbox, assuming you mean the L322. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Exactly the same gearbox in both Andy... & just the reason i purchased a 4.4TDV8 which has the 8 speed...
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 972 ![]() ![]() ![]() |
i reckon that the 4.2 is probably the shout at the mo based on bang per buck! |
The gearbox is the 6HP28, while the older 4.2 SCs have the 6HP26 gearbox. The new box is most likely improved over the older version.
is it 6 or 7 speed? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
according to rrphils chart, its a ZF 6HP26 in the 4.2 and a ZF 6HP28 in the 5.0, both six speed but different last digit...
the only problem i've heard of is the rattly sounding front engine issue which is a timing chains and tensioners problem.... ... - .- -. Y. O. L. O. . |
There are no 7 speed gearboxes in any LR products. |
No 7 Speeds that I'm aware of in JLR products.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6378 ![]() ![]() ![]() |
This is correct Stan, and something I had fixed on mine under warranty. It took the Dealer a week as they dismantle the entire front end of the car to do this work. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
