Home > Technical (L322) > Autolamp Delay
Autolamp Delay
Minor issue with a TDV8 I am selling. On first ignition button push it does nothing but displays "Autolamp Delay" on the LED. Second attemp at pressing button it starts first time. Any ideas?
There are OBD11 codes for various Autolamp delay issues but no idea what they mean?
B1689 Autolamp delay circuit failure
B1690 Autolamp delay circuit open
B1691 Autolamp delay circuit short to battery
B1692 Autolamp delay circuit short to ground
Post #300420 22nd Dec 2014 5:01pm
i think you can turn this off via the indicator stalk or in the menu .....
another thought, does this pop up when the lights are off auto? ... - .- -.
Post #300424 22nd Dec 2014 5:26pm
Thanks Stan that could be helpful.
Client wanted car "as was" but I am trying to find out how to correct but do not have car on drive any more....
What should he do with indicator stalk? (is this in manual)
Post #300429 22nd Dec 2014 5:54pm
JAYBOY
Gaz
Its in the menu on the steering wheel
Thumbs Up 2020 Porsche Panamera Turbo Hybrid (V FAST)
2018 JCW Mini Cooper
2018 Skoda VRS
Post #300430 22nd Dec 2014 6:06pm
Maybe try this
1. Turn the vehicle off.
2. Rotate the headlamp control to the auto lamp position.
3. Rotate the headlamp control to the off position.
4. Turn the vehicle on.
5. Turn the vehicle off.
6. Turn the headlamp control to the auto lamp position (the headlights should turn on).
7. Turn the headlamp control to the off position when the desired delay time (up to three minutes) has been reached.
Post #300431 22nd Dec 2014 6:10pm
Thanks guys will pass the info on mucho appreciated. Just worried its a fault as it stopping the car starting first time for some reason.
Post #300432 22nd Dec 2014 6:12pm
On the disco the auto lamp delay is the thing which keeps the headlamps on for 30 sec after you turn off the car. maybe if this has gone awry then it is causing the issue when you get back in and try to start it.
As has been said, should be able to turn off the autolamp delay in the steering wheel menu and see if the problem disappears. There is nothing that can't be fixed with a hammer😜😜
Post #300434 22nd Dec 2014 6:29pm
will try... Thumbs Up
Post #300451 22nd Dec 2014 7:31pm
