![]() | Home > Maintenance & Mods (L322) > Rear door locks failed... |
| alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6837
Is it cold Craig? Maybe they're frozen up? Got - 2017 SDV8 Autobiography in Loire Blue
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
Had one fail on the disco last year. So it does happen occasionally. But for both to fail at the same time sounds a bit odd😳, would bench test them to prove the failure before ordering new ones, would it not make more sense that it was an electrical failure somewhere rather than 2 failed motors There is nothing that can't be fixed with a hammer😜😜
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Craig,
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Thanks Alan, not been cold here sir & she's kept indoors in a heated workshop/garage... I suspect something simple like a fuse |
Will do |
Thanks Pete, suspect a fuse or control module failure... Ill have a look tomorrow |
You spoil your cars Craig! |
Absolutely i do Alan... |
| sasdiscos Member Since: 16 Oct 2014 Location: Northants Posts: 286
I had one of the rear door controllers fail, i could prove it by switching the passenger and driver side. Doesn't help you though as both have failed. Think it was about 80 quid.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
Both my rear door lock mechanisms failed within 6 months of each other. Warranty paid for each fix on mine.
Well, both door locking motors have failed simultaneously!!! Replaced the pair of them today and we're back in business! VERY VERY ODD! But hay ho... That's FF ownership |
