![]() | Home > In Car Electronics (L322) > MPEG4 tv tuner for MY09 L322? |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
Hi, anyone that have installed the "M44HD DVB-T MPEG-4 TV Tuner" from Eldi in Bulgary?
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1764 ![]() ![]() ![]() |
Doesn't the 2009 MY already have digital TV..? Ash
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35841 ![]() ![]() |
it does but its in mpeg2 .. ... - .- -.
I've got a reply on this from Eldigb:
On my question to this info if the rear camera still will work, and if one can view TV on the headrest screens, the answer was:
That should mean that one can replace the factory installed hybrid TV tuner with this DT1-LR tuner, and then everything will work as it should do, or? Anyone having experience with this equipment?[/code] |
Why would you want MPEG4 compatibility as its really only needed for hd which the ff standard screens can't display? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
jambo27 Member Since: 03 Dec 2013 Location: Staffordshire Posts: 125 ![]() ![]() ![]() |
I think Norway only transmits digital tv in mpeg4 whether its for the HD channel or corresponding SD channel but I could be wrong 2008 TDV8 |
Yes, you are right, Norway only use the Mpeg4 standard in the transmission. |
as said, norway [and ireland] use the mpeg4 system...
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
i had a look at these interfaces.
ok found one myself |
Hi, interesting - I'm not that into the How-To part of this, so maybe a silly question from me: What is the FAKRA-connection to the headunit? And Why is that important?
fakra is the typ of plug for the connection. you need a video connection from the tuner to the sceen in the front.
