![]() | Home > Maintenance & Mods (L322) > Wobble / bobble type vibration |
Check you have not got a rear calliper sticking on sir... Take it for a short run then put your have on/near each rear wheel and check temps... If one is noticeably hotter its probably stuck on sir... Usual FF issue... |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8774 ![]() ![]() ![]() |
As Craig said, and as is the usual advice if one is hot, then have both done cos the other won't be too far behind, not a horrendously expensive job either. There is nothing that can't be fixed with a hammer😜😜
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1525 ![]() ![]() |
I agree with Craig's area to look at. How do the disc faces look and have they ever been changed ? i had a mini where the rear discs looked normal from the outside face, but the inside had corroded to the point the smooth surface had completely gone and was just flaked rust. The calliper had seized as well.
jumbaleo Member Since: 19 Oct 2014 Location: Portsmouth Posts: 41 ![]() ![]() ![]() |
Thank you very much for all your advice, I will get these areas looked at directly.
Just a quick update
