Home > Technical (L322) > Help-Engine not running properly 07 TDV8
jayrt
United Kingdom 2007 Range Rover Vogue SE TDV8 Lucerne Green
I was driving home the other day, parked at some level crossing and the engine started running very lumpy, I continued a further mile home, still not running well with a message on the dash "Engine Management System Fault", I turned it off at home, restarted a few minutes later, still the same, the next morning I tried to start again and still the same ticking over lumpy at around 700 rpm, when the accelerator was pressed the engine died, I have checked the schreider valve under the engine cover when the ignition is turned on and there is some fuel spurting out, today I have plugged a snap on Solus machine borrowed from a friend and the error codes in the ecu are :
P007F charge air cooler temperature sensor - bank 1 and 2 - correlation
P0102 mass or volume air flow circuit low input
Can anybody help please?
Thanks in advance for any help which will be much appreciated
Jason
Post #301447 28th Dec 2014 10:14pm
Split pipe sounds most likely Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #301449 28th Dec 2014 10:15pm
+ 1.
Have a look in the wiki I did a thread on how to check and change one. Easy peasy.
http://www.fullfatrr.com/forum/topic26843.html There is nothing that can't be fixed with a hammer😜😜
Post #301467 28th Dec 2014 10:42pm
jayrt
Thanks guys will have a look tomorrow, I hope thats what it is and nothing too serious!! 2007 TDV8 VSE
Post #301479 28th Dec 2014 10:53pm
jayrt
All the hoses seem ok, maybe air flow meter, EGR? 2007 TDV8 VSE
Post #301895 30th Dec 2014 7:46pm
Did you check under the mesh on the top hose? There is nothing that can't be fixed with a hammer😜😜
Post #301898 30th Dec 2014 7:52pm
jayrt
All the hoses are ok, its the right hand bank EGR valve stuck wide open. 2007 TDV8 VSE
Post #302146 1st Jan 2015 12:12am
Get it changed poste haste my friend... Will cost you at least one turbo if not an engine if left Rolling Eyes Rolling Eyes Rolling Eyes
Post #302155 1st Jan 2015 3:18am
jayrt
I have only driven 2 miles since it happened, stripping it today, hope its not too bad a job! 2007 TDV8 VSE
Post #302161 1st Jan 2015 10:18am
A lot to take off but all quite straight forward sir Thumbs Up
Post #302168 1st Jan 2015 11:02am
jayrt
Has anyone any tips or advice before I start, does the scuttle centre panel need to come off to get the manifold out? 2007 TDV8 VSE
Post #302186 1st Jan 2015 1:21pm
Mikey
Pretty fiddly, and time consuming, and quite a few electrical connectors to come off, but nothing too difficult Thumbs Up
Post #302190 1st Jan 2015 2:14pm
jayrt
Thanks for the info, every little bit helps. 2007 TDV8 VSE
Post #302194 1st Jan 2015 2:20pm
been toying with doing mine as a preventative measure, might not be a job for me on the drive though..... i would be bound to lose some nuts and bolts in the process.
Does everything come off easily, Im not phased by taking the bits off but am wondering if there is anything you have to fight with. Do the require any coding once in? There is nothing that can't be fixed with a hammer😜😜
Post #302199 1st Jan 2015 3:22pm
Mikey
Injector covers can be a right Censored
Post #302203 1st Jan 2015 3:42pm
