Home > Technical (L322) > heated screen info required
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Well it looks like a new screen needed as last night the heated screen wouldn't clear the mist inside and frost too Big Cry
Before getting autoglass out im after some info, where do the wires run for the heated screen , which 'a' pillar or are they in both. Want to check continuity to make sure the screen IS foobared and how the heck do you get the airbag badge off the a pillar trim?
Thumbs Up If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #302014 31st Dec 2014 11:23am
Airbag Badge - in RAVE it just appears to be clipped in, may require "effort"
Caution: Disconnect battery and let SRS system die first.
Seems also there are connectors under both A pillar trims (inside) but I seem to remember there were connections to the screen lurking below the scuttle/air intake at the lower front of the screen outside. .
Post #302015 31st Dec 2014 11:41am
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
The airbag badge does just clip off but its quite hard to do, I was worried I waas going to break mine when I did it but eventually it popped off.
Post #302018 31st Dec 2014 11:48am
Welshdragon
Thanks Tim and Fish Thumbs Up
Will attack it in a little while, much appreciated Bow down Thumbs Up Thumbs Up Thumbs Up If it dont work.......burn it!
Post #302022 31st Dec 2014 12:23pm
