Home > General > Do you drop the suspension when parked overnight?
Page 3 of 5 <12345>
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Have no choice with mine, as swmbo has to have the eas lowered for easy access. She also lowers the electric seat to get out, and raises again when in. So time will tell how long everything lasts. Laughing
greg
Post #302608 4th Jan 2015 6:57am
allycraven
If I recall correctly, lowering to access height should be done whilst approaching the parking spot rather than when stationary to reduce stress on suspension components..
As mentioned before, it also significantly reduces wear on the seat bolster from sliding out...
Always did it in mine when I had it.... '08 Audi S6 Avant 5.2 V10 with Milltek non-resonated. Vrrrrrrmmmmmph
'59 Ford Kuga Diesel (boring but AWD and 40mpg...)
2007 (07) Subaru Forester XTen 2.5 Turbo. (Roundabouts are fun again!)
2007 (07) 4.4 V8 Vogue (gone)
Post #302610 4th Jan 2015 7:14am
gregdav
Yep it's in the handbook. Thumbs Up
Post #302611 4th Jan 2015 7:51am
supershuttle
I'm a bit of a lowerer (if thats a word) when costing to a stop outside the house I hit the button on the door panel. I have to say its when I remember though, because I also am a bit lanky (though not as much as Criag Rolling with laughter ) and even lowered I still slide off the seat putting additional wear and tear on the seat bolsters.
SWMBO always slides off - raised on not - she must think she's on a fairground ride. Very Happy Geoff
Post #302612 4th Jan 2015 8:18am
And the Semi Aniline seats in your latest car will wear at a much quicker rate too Geoff... It'll be a good habit to get into sir Thumbs Up
Post #302614 4th Jan 2015 8:57am
Java Jungle
Monaco 2011 Range Rover Autobiography 4.4 V8 Nara Bronze
Good to know about the column function, mine is always on....
Can it be turned off independently from the seat lowering itself? Since I'm sitting high I like the seat getting down and less wear on the leather. Or is the whole "easy exit" eventually Censored hitting the fan.... Laughing
Thanks,
JJ
Post #302694 4th Jan 2015 6:19pm
Andy S
United Kingdom 2015 Range Rover Vogue SE SDV8 Aintree Green
Craig
I didn't realise you could switch the column off. In my car (2010 my VSE) when I open the door after switching off, the seat lowers and the wheel moves away and up. It's supposed too do that. I know older cars had problems, but I thought LR had redesigned the column by the time my car came along. I've got a LR warranty, so if it or anything else goes I'm covered. I've owned LR products for over 15 years and always kept them warranted because there is always something that will go.
I too am over 6' and lower the suspension to avoid too much wear on the bolster. My car has semi aniline and looking at the seat base, I'm guessing the previous owner was a big lad who didn't take so much care. The other seats are perfect, the driver's a little worn on the right side.
Post #302707 4th Jan 2015 7:49pm
Thumbs Up Thumbs Up Thumbs Up
Post #302710 4th Jan 2015 8:16pm
Thanks,
JJ
No sir it cannot I'm afraid Rolling Eyes
Post #302711 4th Jan 2015 8:17pm
Java Jungle
Yup, that's what I thought Rolling Eyes
Thanks!
JJ
Post #302727 4th Jan 2015 9:04pm
miggit wrote:
SKOT, if you keep refilling your suspension with new air, you will be causing more moisture not less. I think its better to suffer the small amount of moisture in the system, rather than refill it with moisture laden air every time you use the car. Besides which, the moisture trap in the compressor is not of a drain off type, it is more along the lines of silica gel and will become exhausted in time. This will mean that one day it wont be able to supply enough air to lift the car, then it will be BONG! time, along with the screen of DOOM telling you your shagged and you can't go over 35 MPH. It's a pain when it happens, and the Great God Sod will make sure that your 25 + miles from home went it happens Shocked
When the air suspension deflates it passes the, dry, exhaled air back through the drying medium to dry it.... it is designed with a venturi to raise the temp of the air and so aid drying so the medium is always dry for the next fill....
Not using it will cause moisture from the ambient air to saturate the medium and do damage to the pump and other parts of the system.
The only thing that wears is the piston ring and these are now available for a cheap cost...
The pumps get damaged when people don't recognise the symptom of slow raising, i.e. worn piston ring, and continue to let the poor compressor work it's heart out trying to fill the system..
As with most things, you have to know how it works, when it is working correctly, to recognise when it has problems... Pete
Post #302752 4th Jan 2015 10:26pm
miggit
I'll second that thought, mine was worn out when I brought the car, but I just thought that the slow raising was normal. It was only after it had failed and I'd fitted a new piston ring, that I realised it really was Censored and would need a complete replacement Sad
Having fitted a new pump it will now go from low to high in just over a minute, anything longer than 1'30" and you should be replacing the piston ring asap. And if yours is taking 2 minutes plus, I'd strip it and check the bore before ordering a piston ring, if there are any scratches on the bore then I'd save the piston ring money and put it towards a new pump.
I couldn't afford to replace the pump at the time, so I fitted the piston ring that I'd ordered (before stripping the pump) and it lasted for about 4 months, before it became F U B A R'd and I was forced to fit a new unit. It takes longer to empty the boot and remove the spare wheel, than it does to remove and strip the pump. And if your boot is empty then I'd bank on 30 minutes start to finish. There are a few write ups on here and there are a load of videos on You Tube Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #302786 5th Jan 2015 12:14am
CEEGEE
Practicalities aside - they do look "cool" when lowered Cool
Post #302798 5th Jan 2015 12:48am
miggit
If I wanted something near the ground I'd have brought a Bentley, it's a 4 x 4, it's supposed to be high, so you can go were others can't! I want to be above the rest of the world and look down on them Twisted Evil Yesterday I couldn't spell Engineer... Today I are one!
Post #302805 5th Jan 2015 1:09am
I have to lower mine to get in the garage so I simply hit the button when I press the button for the door but It has been mentioned here before that the car knows to go to sleep quicker in access height and when they wake to adjust their level they only try to equal out all four wheels not try to actually level to the horizon so to speak.
As an aside my car is on its original compressor and only takes 15-20 seconds to go from access to off road and my last one was the same. 2008 MY Supercharged
Post #302807 5th Jan 2015 2:27am
Page 3 of 5 <12345>
