Home > Wheels & Tyres > RR snow chains or LR Snow Traction System |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
The issue with traditional chains is that they require good clearance between the wheel and suspension/brake components.
5th Jan 2015 7:04pm |
GenevaRR Member Since: 28 Apr 2013 Location: Oundle Posts: 11 |
Thanks I will look up the Spider Spykes.
5th Jan 2015 7:14pm |
Check the manual, I have vague recollections that 1 pair is enough. |
5th Jan 2015 7:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34918 |
the FF has a 50/50 power distribution to the front and rear wheels so i would put these on both axles to be safe. ... - .- -.
5th Jan 2015 8:21pm |
Chains would be good if you had a scruffy set of alloy wheels as well as they invariably will leave some marks on them.
5th Jan 2015 8:51pm |
I thought about 19 inch rims but I was told that they would not fit over the large brake callipers on the Westminster.
5th Jan 2015 9:38pm |
I looked up the Spider Spikes on the link provided - thanks
5th Jan 2015 9:41pm |
Noooo, only put chains on the rear!!!
5th Jan 2015 9:51pm |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
Land Rover recommends fitting the snow traction system on the front wheels only for the L322 and on the back wheels only for the L405. I have no idea why the recommendations are different from one generation to the other but that's what the official recommendation is.
5th Jan 2015 9:52pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
I have a spare set somewhere... |
5th Jan 2015 9:57pm |
I believe there is a certain style of 19" wheels that just clear those calipers for this express purpose, they are 11 spoke I think and mentioned in a post in general when someone looked at a 2010 sc that had the wrong wheels fitted to it.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
5th Jan 2015 10:00pm |
These ones Will
5th Jan 2015 10:09pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7760 |
As stated already - manual says rear axle only - there isn't enough clearance on the fronts
5th Jan 2015 10:28pm |
Thanks for pic
5th Jan 2015 10:29pm |
