Home > Maintenance & Mods (L322) > North American spec rear lights
Robgosty
Just ordered some of these and wondered if anyone knew which plug is used for the side markers, I know it's not fitted on car so will have to chop one from a scrapper and use that, must use use same size plug somewhere on car, just need to know where Thumbs Up
Post #303094 6th Jan 2015 12:32pm
probably 501 bulbs
Post #303098 6th Jan 2015 12:42pm
Robgosty
Hi Stan, bulb holders come with lights, I am after the plug that goes into the bulb-holder Thumbs Up
Post #303103 6th Jan 2015 1:47pm
do you mean something like this,
Post #303105 6th Jan 2015 2:08pm
Robgosty
No, it looks like a proper two pin plug will try and find a pic when I get home, they are the same as shown here e bay item number eBay Item No. 331434965344
Post #303117 6th Jan 2015 2:56pm
i see which one you need now Thumbs Up ....i'd troll ebay and hopefully come across teh right plug..
or if there's a centre separator inside the plug bit you could stick a wire in each side and drop a bit of solder in there... ... - .- -.
Post #303118 6th Jan 2015 2:59pm
Robgosty
Thanks Stan, soldering seems a good plan B, I was looking to do it properly with the right plug but it looks like it will be easier to solder direct to bulb holder Thumbs Up
Post #303124 6th Jan 2015 3:09pm
