|  | Home > Maintenance & Mods (L322) > Rear Led Tail light conversion wiring thought |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669    |
 I have a broken rear light   | ||
|  5th Jan 2015 6:51pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | i think its more complicated than that and these resisters do get hot if left on for a while...afaik there's a constant live which is switched by impulses from the ecu when each light is required...
|  5th Jan 2015 7:11pm |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669    | Yes I was looking at the clear super changed one's, but I'd probably break them too   | ||
|  5th Jan 2015 7:42pm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35883    | craig does a lot of conversions and he might be able to give some expert thoughts on the 'adapters' for the 2010/12 led lights.. ... - .- -.
|  5th Jan 2015 7:45pm |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669    | Are but that will cost me £650 fitted   | ||
|  5th Jan 2015 8:01pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      |
 Sorry Stan, we haven't, don't and won't fit resistor kits   | ||
|  5th Jan 2015 8:51pm |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669    | So from that I can assume that you've some way of reprogramming on the board monitoring system, and what sort of damage would we be talking if I were to fit the lights and you make 'em work   | ||
|  5th Jan 2015 9:00pm |
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403      | Rear light prices are on the website sir  | ||
|  6th Jan 2015 12:47am |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863      | scored a set of 2012 tails for $525 shipped.  Looking forward to the update this weekend  | ||
|  6th Jan 2015 5:05pm |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669    | Having read lots of posts about light fitting, and different voltages, I have decided to go the Supercharged route. Mainly because I know that a FFRR is sensitive about electrical changes, and I wouldn't want to upset the apple cart, so to speak   | ||
|  6th Jan 2015 5:49pm |
| miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3669    | Just a thought, do you think it's wise to employ some epoxy resin and go over all the seams before fitting them, or should I take a chance that I've got the only fully sealed set to come from the factory ?   | ||
|  6th Jan 2015 5:53pm |
| Posting Rules
 , I got a replacement s/h rear light and it didn't want to go on
 , I got a replacement s/h rear light and it didn't want to go on   I pushed the
 I pushed the   light and it's now more
