![]() | Home > Maintenance & Mods (L322) > powerful uk door handle covers/others-feedback |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
They need a little help to keep them in place, I used some polyurethane flex adhesive. One because it's what they stick commercial lorry bodies together with, and two, because I had an open tube to hand |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
My Powerful covers just stuck right out of the box.
Thanks all (I knew it wasn't silicone sealant for a bath, honest |
tony66 Member Since: 01 Dec 2014 Location: fife Posts: 92 ![]() ![]() ![]() |
i"ve bought a set but not from powerful -cheaper item at £21.99 posted[yes tight scotsman]
Ryan.... |
Si |
Yes. My set came with a keyhole opening cover and a full cover and left it up to me to decide which to fit.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
If you use stuff called "Sikaflex", they'll never come off! |
^^ "Sikaflex" is polyurethane flex adhesive! Only that's the brand name, rather than the product, like Hoover and vacuum cleaner |
they look good-hope my chromalikes look as decent as those.. |
I suppose that the only difference than you'll be likely to notice is the ABS chrome handles are more likely to be warmer to the touch |
Do many people who put colour coded door handles on, also put Powerful's colour coded mirror covers on and do they also colour code the tailgate strip, side vents and bonnet scuttle? |
I personally can't see the point in putting on handle covers that are painted, especially if your contemplating colour coding the bonnet scuttle, if your going to do that then you might as well save £50 and paint the handles too |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
I been thinking of fitting these covers on mine for a while now, but not sure which way to go, titanium is preferable ( I think) or body colour |
