Home > Maintenance & Mods (L322) > Towbar Question
Page 1 of 5 12345>
devonchilliman
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Towbar Question
Evening gents Thumbs Up
Just bought my first FFRR Mr. Green Mr. Green ....
I will be having a multi height towbar fitted,but I'm concerned that IMHO they are easily removed Whistle,the vehicle will be used for towing most days and to remove the towbar every day will be a pain,has anyone made theirs more secure?,I was wondering wether to get it spot welded somewhere...thoughts/ideas appreciated thanks
Post #303234 7th Jan 2015 12:08am
supershuttle
My old one just rusted solidly into place, but you could just replace the Pin and K Clip with a nut and bolt or even replace the clip with a small padlock (a bigger one if you drilled the hole out). Geoff
Post #303239 7th Jan 2015 12:23am
johnboyairey
I think you are thinking that the slide pin and R clip are easily removed and then the insert is slid out. You could measure and buy a bolt and nylock nut. The bolt should be only threaded at the last inch, so the shaft stays snug. This could only really be emroved with a ratchet and a spanner, making it rattle less, and more secure.
You could also look for a long shackled padlock, and swap it for the R clip. and drill the slide pin a little to fit it. But it might get full of silt and never reopen. The towbars are expensive, so are worth thinking about.
Post #303240 7th Jan 2015 12:24am
devonchilliman
Thanks,I can't believe that LR don't do a more secure/permanent one
Post #303290 7th Jan 2015 10:16am
johnboyairey
Nowadays, with the modern Range Rover, its easier and qicker, to just steal the whole car, rather than just take the sundries bolted to it! what a world we live in!
Post #303297 7th Jan 2015 10:32am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
LR do a replacement nut and bolt and it is torqued up pretty high.
Stops the annoying rattle.
Ian
Post #303324 7th Jan 2015 11:45am
devonchilliman
Rattle Shocked ?? Can't be doing with that
Post #303356 7th Jan 2015 1:33pm
IanV8
Rattle - that's why my dealer did the mod.
Can't post picture as that car has now gone.
Ian
Post #303593 8th Jan 2015 10:23am
devonchilliman
No worries Thumbs Up
Post #303636 8th Jan 2015 3:04pm
martinf
United Kingdom 2016 Range Rover Vogue TDV6 Santorini Black
There is a modified drop plate tow bar with a bolt instead of a pin to secure it. Originally this was offered if the owner complained that the standard tow bar rattled.
The part number is VUB503110. I bought one in 2010 but have no idea if it is still available.
Post #303697 8th Jan 2015 7:47pm
There were 3 options - one with a hole through and a pin, the same but with a bolt and a third with a partially threaded hole & a bolt.
I had the middle one, but changed the bolt for a pin as I generally take it out when not in use & don't find it rattles with a trailer that has decent nose weight.
I also have the threaded option which I bought as a 'spare' and leave in Bordeaux - I did that after arriving there to remember that I'd left the tow hitch on my garage floor & had to pay the storage people to launch & retrieve my boat Embarassed
The threaded one is no doubt better if you're leaving it permanently installed - I only have that one as i got it at a good price second hand.
Post #303701 8th Jan 2015 7:59pm
devonchilliman
Cheers chaps Thumbs Up ...I will leave it on permantly so will go the bolt/nut route and probably get it spot welded as an extra precaution
Post #303707 8th Jan 2015 8:20pm
martinf
The part number I quoted above is for Alistair's third option. Once it is tightened up properly nobody is likely to steal it.
Post #303720 8th Jan 2015 8:48pm
devonchilliman
Don't suppose you have a pic of the part (VUB503110) Thumbs Up
Post #303733 8th Jan 2015 9:35pm
supershuttle
Worth a look at the ABUS Expedition Padlock - might have to drill out the pin a bit. Geoff
Post #303739 8th Jan 2015 9:49pm
Page 1 of 5 12345>
