Home > Maintenance & Mods (L322) > 4.4 V8 engine question - cone shaped filter
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Please excuse my ignorance and I have not taken any pictures yet but I notice in my engine bay at the front on the left is a cone shaped filter of some sort. Just above that is a large square box that I assume is the air filter? Fairly large, around 10-12 inches in length. Any ideas what this is?
I can provide pics if required Smile but the weather is bad and it's dark at the moment.
EDIT - attaching a picture, not of my engine but I have circled in red what I don't have, in it's place is a cone shaped filter of some sort.
I am wondering if this had to be changed when it had the 2006 facelift?
Post #303452 7th Jan 2015 5:36pm
johnboyairey
if you have had the front headlights 'facelifted.' then the old missing box wont fit behind the newer bigger type. , so you use a cone type AIR FILTER. like a K+N make, there will also be a smaller one tucked in behind it, under the bonnet panel. on a vertical pipe. as that pipe would normally have gone into old box too. it makes the engine a bit more roar-ey on foot down accelleration too. mine has one, but mine is a little loose, and should really be braced with a small tie-piece of metal to the bonnet slam panel, to stop it wiggling when driving on rough terrain. (from the jubille clamp. ) the filter connnects to the AFM or air flow meter, sometimes called 'mass airflow' or MAF thats the tube next to the cone, with a connector these are a little brittle inside, and so the sturdyness of the cone is to protect the MAF/AFM
Those cone filters have different ways of cleaning/ change-out milage distances. they are only about £15 you need to know the hole size.
Post #303458 7th Jan 2015 5:53pm
scwilson
ah - ok that explains it. Thanks. I have noticed it roars when accelerating but not as much as a friends 1989 Range Rover, that makes a proper loud V8 roar.
Post #303462 7th Jan 2015 5:59pm
johnboyairey
your only drawback using the cone, is its ever so slight risk to water ingress against the enclosed type if you were wading in VERY deep water with a bow-wave, as the original would be drawing air from the inner wing (i think.)
Post #303465 7th Jan 2015 6:03pm
scwilson
Thanks for the info regarding the bow wave, the only time this would happen is if I'm hit by a Tsunami. I don't off road or like to take the car in deep puddles/rivers Smile
Post #303642 8th Jan 2015 2:48pm
They sound great Thumbs Up
Post #303726 8th Jan 2015 8:11pm
scwilson
So what is the best modification you can make to these 4.4v8 engines to make them sound like a monster?
Post #303821 9th Jan 2015 9:11am
jaybear
France
Only option will be the exhaust , but it won't be legal .......
Anyway this kind of vehicle prides itself to be high end limousine and infact soundproofing is superb on these vehicles .
So tryng to get V8 Roaaar on a L322 is against it's nature . Jaybear
2002 V8 , premier edition , 19" alloys ,
Post #303837 9th Jan 2015 11:17am
