Home > Off Topic > Any mountain bikers here ?
Johnte
Can I pick your brains (me knowing nothing about bikes) Whistle
My son broke his bike at the weekend.. cracked the frame - which I don't think would be really repairable.
I would like to swap all his parts out onto another frame, but do I need to buy the same brand (Scott) or items such as forks,brakes,gears etc universal fitting.
Sorry for the stupid question Big Cry
Post #303555 8th Jan 2015 12:33am
Ideally you'll want to stick to the same frame as then you know it will all bolt off and onto the new one but there are likley other frames that all the bits will fit onto, it depends on the rear suspension mounting points more than anything.
have you checked to see if replacement frames are available? How old is the frame as well as if it still has its serial tag on the bottom bracket it may be under warranty or Scott may contribute towards a newer version of the frame? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #303569 8th Jan 2015 3:22am
Johnte
Thanks.. I think you're maybe right - if I can find a frame exactly the same, it would make it a much simpler job for me Thumbs Up
As far as warranties go, I think it will be well out now - it's a 2006 model Sad
Post #303582 8th Jan 2015 9:36am
It's always worth an ask as you'd expect them to last a bit longer Smile
I had a bike years ago with a 15yr warranty on forks and frame; I got 3 fork sets and 1 frame out of them before the bike was binned 😄😄 it wasn't a Scott mind but a Raliegh iirc. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #303583 8th Jan 2015 9:45am
A1GSS
I'd have thought it was an ideal opportunity to go shopping for a new one... Thumbs Up Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #303584 8th Jan 2015 9:50am
CEEGEE
I have built a few road and mountain bikes up - the only part which is likely to be restrictive (but still not unique) is the rear suspension, otherwise parts should be easily "transferable" - but you'll obviously have to re-cable it.
If you are buying a new frame, and the old bike has had a lot of wear (judging by the pics), I would recommend looking carefully at all the other components, chances are some of them are very worn, etc and probably warrant being changed - also, there has been a lot of positive development since 2006 in terms of the performance of brakes and group-sets, etc, so perhaps it might be time to consider a whole new bike.
When you buy a new bike, the group-sets and finishing kit etc is bought by the builders so much more cheaply (because of volume), that unless you are building a very specific specification, or high end, its better to buy a built bike new.
If you did this, the parts of the old one would be likely to sell on ebay easily - I have bought and sold lots of bike parts on here. Likewise, if you are intent on buying another frame, don't rule out a second-hand one - just be careful.
To be honest, the more I think about it, and based on your pics, I am just not sure I'd be putting 2006, well worn parts on a brand new frame - it could end up as a bit of a false economy.
Hope this helps Thumbs Up
Post #303585 8th Jan 2015 9:53am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
All the parts should be interchangeable with a new frame except the rear Genius shock, which is a specific Scott design for the Ransom (I have a carbon Ransom - awesome bike, I love it!)
I think I've see your bike for sale on eBay - there are also a couple of frames for sale if you go down that route
Steel frame with Fox shock (not sure how well the Fox would perform, the Genius has a variable resistance through its stroke and I don't believe the Fox does
http://m.ebay.co.uk/itm/291347632121?nav=SEARCH
Carbon frame with some high end kit
http://m.ebay.co.uk/itm/321622004994?nav=SEARCH
Personally I'm very happy with my 08 Ransom Ltd - it's awesome downhill!! 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #303590 8th Jan 2015 10:11am
Johnte
I suppose ideally we should be looking for a new one, but he's really getting into road biking now, and would like to upgrade his road bike. So is desperately saving his paper round money.
I guess his biking is now 90% road, and 10% off road (local woods + Dalby forest), so not worth spending lots on this one.
I think a used frame, and 'budget' rebuild, could be the way forward for this one Whistle
Post #303694 8th Jan 2015 7:41pm
CEEGEE
Sounds like a plan - I bought a second-hand winter road frame off ebay, and its been fine Thumbs Up
Ideally if you go for a second-hand one aim to pick it up so that you can give it a good look over to make sure there are no hairline cracks, or stress marks Thumbs Up
Post #303736 8th Jan 2015 9:46pm
