Home > Maintenance & Mods (L322) > Do the wing mirror puddle lights need error free leds ?
Page 2 of 3 <123>
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Ordered !
cheers stan Thumbs Up Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #303459 7th Jan 2015 5:56pm
Thumbs Up ... - .- -.
Post #303463 7th Jan 2015 6:01pm
Stan, how bright are they compared to OE pal? Seen a couple which were yes blue... But quite dull in comparison...
Post #303556 7th Jan 2015 11:47pm
technically these 6000k bulbs have less light out put than the 43000k OE ones but because they are a whiter light in my eyes they equal or better the OE bulbs... ... - .- -.
Post #303580 8th Jan 2015 8:25am
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
markcaughey wrote:
Error free bulbs came today for the side lights. Quickly tested them in the mirrors and they work fine. So I will be ordering a few more and think I will get the number plate ones as well.... addicted Very Happy
Also really like how the headlights come out nice and simple to change the bulb. None of this lying and the ground, wheels at full lock, aimlessly fidling about in the wheel well, hands bleeding trying to change a damn bulb Big Cry
can you link me to the ones you used in the mirrors? How involved is it to get to/replace them? I thought i recalled you have to remove the whole mirror etc.?
PS...if you want the whitest/brightest OEM look for LED's ALWAYS go with CREE. Those are the only ones I do nowadays for all my cars. You will be able to tell its CREE as the LED looks like it has a clear shell and then a green chip inside it.
Post #303652 8th Jan 2015 4:13pm
COB [chip on board] are brighter for 'blanket' light.. ... - .- -.
Post #303653 8th Jan 2015 4:20pm
markcaughey
to remove the bulb housing point the mirror glass toward the sky to allow access at the bottom. if you shine a torch in you should see the the clip for the bulb housing. i released it using a thin screw driver. can be tricky but once you have done it a few times its a doodle.
bulbs i used - http://www.ebay.co.uk/itm/111327537215
managed to get into the roof interior lights but the bulbs i have won't fit Big Cry need to try and find some that aren't so thick. Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #303655 8th Jan 2015 4:30pm
horse86
thanks buddy! are those LEDs in the mirrors bright crisp white or more blue?
Post #303658 8th Jan 2015 4:41pm
markcaughey
yeah nice white light.
the interior ones i got are a tad blue though, only really noticeable on the upper footwell spot lights. may order some cree leds for these.
can anyone link me to leds that will fit the interior roof lights. thanks Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #303675 8th Jan 2015 5:56pm
Mark, there are LED blocks available with a fitting kit (for any bulb holder) on the bay of e! "been covered here several times!" that will give you much more light than a single replacement bulb Thumbs Up
Im sure someone will be along with a link shortly Thumbs Up
Post #303681 8th Jan 2015 6:22pm
If you take the two hidden screws out then the front of the light comes off for fitting Thumbs Up
Post #303682 8th Jan 2015 6:24pm
markcaughey
http://www.fullfatrr.com/gallery/albums/us...re~209.PNG
saw these but the bulb fitting is still the same so that won't fit either Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #303696 8th Jan 2015 6:44pm
horse86
go on.....
Post #303704 8th Jan 2015 7:14pm
markcaughey
got my number plate lights through the post today. looks great and no errors but i have noticed that the side lights and number plate lights flicker on start up for around 5 seconds then fine. anyway i can sort this out ? Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #303840 9th Jan 2015 12:32pm
if you switch off cold and hot monitoring with the iidtool ,this should stop the flickering. ... - .- -.
Post #303843 9th Jan 2015 12:40pm
Page 2 of 3 <123>
