Home > Technical (L322) > HORN or more to the point lack of
dingg1
took it in for MOT today , horn not working -hmmm was working okay yesterday
looked in handbook to check which fuse and it doesn't indicate which it is
anyone know which one it is??
cheers
Post #303881 9th Jan 2015 4:52pm
theres a fuse for the horn in the big black box on the left handside in the engine compartment..its right on the left at the top.. ... - .- -.
Post #303882 9th Jan 2015 4:54pm
dingg1
thanks Stan
will have a peep in the morning (pun intended)
Post #303891 9th Jan 2015 5:40pm
dingg1
Fuse checked and is intact , changed it out anyway , still NO HORN
I can hear associated relay clicking when trying the horn.
Post #304021 10th Jan 2015 11:22am
They are pretty much behind the drivers fog light (bolted to the end of the crash bar)... There are two of them and i'de be surprised if they both failed! but not impossible...
I guess the only way to know for certain will be to remove the bumper and check for power at the plugs sir Bow down
Post #304022 10th Jan 2015 11:29am
WM says theres an access panel in the wheel arch, can it be 'got to' from there craig?
Post #304024 10th Jan 2015 11:38am
Ahh... Never know there was a removable panel there on a TDV8 Stan... Thought the rad/cooler thats mounted behind there would be in the way! You sure thats not for either a V8 or TD6? Stan???
Post #304029 10th Jan 2015 11:46am
it doesnt specify any model type in the manaul craig .. ... - .- -.
Post #304032 10th Jan 2015 11:55am
Whistle Whistle Whistle Well, I'm not convinced that would work Stan... So, we will await a response from the OP i guess pal Thumbs Up Thumbs Up Thumbs Up
Post #304035 10th Jan 2015 11:57am
Thumbs Up ... - .- -.
Post #304037 10th Jan 2015 12:09pm
Bow down Thumbs Up Bow down
Post #304039 10th Jan 2015 12:10pm
dingg1
cheers guys , it'll have to wait for better weather , so may be a while.
the horn did sound quite 'weedy' for the size of vehicle so it may well be the second sounder has failed
Post #304044 10th Jan 2015 1:02pm
Sounds like one unit has failed and as usual the other shortly after!
Best to replace them both Very Happy Stabil Nautilus i think are semi decent and there are plenty of decent copies out there. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #304058 10th Jan 2015 3:18pm
