![]() | Home > My Range Rover > CY's 2002 Td6 Epsom Green Vogue |
| Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1902
| CY Member Since: 27 Mar 2007 Location: Scotland Posts: 146
What's an IId... |
| Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1885
IID Tool. Plenty of info back over on D3, As well as here |
Yes similar but have a look at this, Pat and team are site sponsor's too.
| chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 766
Looks like I'll be following you too! Soon!! David |
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
If you've got a Hawkeye for the D2 it can also work for the FFRR if you buy the relevant codes. Don't know the extent of the coverage. You can check it against the iiD spec.
Need to bring your new Range Rover to Glentarkie ! See how it does!!
Hi All,
| Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128
WOW |
| horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863
How did you get the 2010 front bumper splitter bar to fit/work? I really like that!
Andy,
Horse86 - the silver strip can be purchased from PowerfulUK (link below). Yes it's simple plug and play - use alcohol wipes (provided) to cleanse the surface and then it's simply a cover which sticks on over the existing body-coloured part. I suggest using a couple of strips of 3M Automotive Tape on the bumper too just to hold it in place securely |
| betonklinker Member Since: 19 Nov 2015 Location: Amsterdam / Netherlands Posts: 68
Nice and I also like the bumper splitter |
CY...do you know if its an OEM piece...specifically the 2010 OEM piece that just so happens to fit? Or is it a custom piece? Reason I ask is the 2010 OEM part can be found for cheaper and it would save me a lot on shipping across the pond.
| All times are GMT |
